node-red-contrib-usbhid-path 1.3.1
A node-hid wrapper for Node-RED with path-based device selection support
npm install node-red-contrib-usbhid-path
A fork of node-red-contrib-usbhid that adds path-based device selection support. This enhancement is particularly useful when working with multiple identical devices that share the same VID/PID.
Credits
This package is based on node-red-contrib-usbhid by @gdziuba. The original package provided the foundation for USB HID communication in Node-RED, and this fork adds path-based device selection capabilities while maintaining compatibility with the original package.
Acknowledgments
  • All the features of the original package
  • Path-based device selection support
  • Non-conflicting node names (uses -p suffix)
  • Device picker in configuration node
This package provides three nodes with -p suffix to avoid conflicts with the original package:
  1. hidconfig-p - Configuration node with path-based device selection
    • Configure by VID/PID or device path
    • Built-in device picker shows available devices
    • Shows device paths for easy identification
  2. gethiddevices-p - List available HID devices
    • Lists all connected USB HID devices
    • Includes device paths in the output
    • Useful for device discovery
  3. hiddevice-p - Communicate with HID devices
    • Send and receive data from HID devices
    • Auto-reconnect on device disconnect
    • Three outputs:
      • Output 1: Data received from device
      • Output 2: Error messages
      • Output 3: Connection status updates
Prerequisites
  • Node.js v0.8 - v4.x+
  • Mac OS X 10.8, Linux (kernel 2.6+), and Windows XP+
  • libudev-dev, libusb-1.0-0-dev (if Linux, see Compile below)
  • git
node-hid uses node-pre-gyp to store pre-built binary bundles, so usually no compiler is needed to install.
Platforms we pre-build binaries for:
  • Mac OS X x64: v0.10, v0.12, v4.2.x
  • Windows x64 & x86: v0.10, v0.12, v4.2.x
  • Linux Debian/Ubuntu x64: v4.2.x
  • Raspberry Pi arm: v4.2.x
From Source
cd ~/.node-red/node-modules
git clone https://github.com/jpkelly/node-red-contrib-usbhid-path.git
cd node-red-contrib-usbhid-path
npm install
Linux USB Permissions
For Linux systems, you need to set up proper USB permissions:
  1. Install required libraries:
sudo apt install libusb-1.0-0 libusb-1.0-0-dev libudev-dev
  1. Create udev rules:
sudo mkdir -p /etc/udev/rules.d
sudo nano /etc/udev/rules.d/85-pure-data.rules
  1. Add the following rules (update KERNEL for your device):
SUBSYSTEM=="input", GROUP="input", MODE="0777"
SUBSYSTEM=="usb", MODE:="777", GROUP="input"
KERNEL=="hidraw*", MODE="0777", GROUP="input"
  1. Set up input group:
sudo groupadd -f input
sudo gpasswd -a $USER input
  1. Reload rules and reboot:
sudo udevadm control --reload-rules
sudo reboot
  1. Add a hidconfig-p node to configure your device:
    • Enter VID/PID, or
    • Use the device picker to select by path
    • (Optional) Set interface number if needed
  2. Use gethiddevices-p to list available devices:
    • Connect to an inject node to trigger
    • View device details in debug node
  3. Use hiddevice-p to communicate:
    • Configure with a hidconfig-p node
    • Input: Buffer or Array payload
    • Output 1: Received data
    • Output 2: Errors
Connection Status Output
The hiddevice-p node provides real-time connection status through its third output. The status message format is:
    topic: "status",
    payload: {
        fill: "green" | "yellow" | "red",  // Status color
        shape: "dot" | "ring",            // Status shape
        text: "connected" | "disconnected" | "reconnecting in Xs"  // Status text
    timestamp: 1234567890  // Timestamp of status change
Status indicators:
  • 🟢 Green: Device connected and ready (includes device details)
  • 🟡 Yellow: Attempting to reconnect
  • 🟥 Red: Device disconnected
The connection status includes detailed device information in the payload:
    topic: "status",
    payload: {
        fill: "green",
        shape: "dot",
        text: "connected to Barcode Scanner (/dev/hidraw0)",  // Human-readable status
        device: {
            product: "Barcode Scanner",      // Device name if available
            vendorId: 1234,                  // Vendor ID
            productId: 5678,                 // Product ID
            path: "/dev/hidraw0",           // Device path
            serialNumber: "ABC123",          // Serial number if available
            interface: 0                     // Interface number if applicable
Example Flow: Status Display
Here's an example of how to use the connection status output with a UI LED and text display:
        "id": "015f81a5e59b3ab8",
        "type": "function",
        "name": "Parse Connection Status",
        "func": "// Log incoming message for debugging\nnode.log(\"Incoming message: \" + JSON.stringify(msg));\n\n// Get the status from the incoming message\nconst status = msg.payload;\n\nif (status && status.fill) {\n    // Create two separate messages\n    const ledMsg = { payload: 3 };  // Default to red\n    const textMsg = { payload: status.text };  // Use the actual status text\n\n    // Set LED color based on status\n    switch(status.fill) {\n        case \"green\":\n            ledMsg.payload = 1;  // Green\n            break;\n        case \"yellow\":\n            ledMsg.payload = 2;  // Yellow\n            break;\n        case \"red\":\n            ledMsg.payload = 3;  // Red\n            break;\n    }\n    \n    node.log(\"Setting LED state to: \" + ledMsg.payload);\n    node.log(\"Setting status text to: \" + textMsg.payload);\n\n    // Return array of messages [LED message, Text message]\n    return [ledMsg, textMsg];\n} else {\n    // Handle invalid status\n    return [{payload: 3}, {payload: \"Unknown status\"}];\n}",
        "outputs": 2,
        "noerr": 0
To use this example:
  1. Connect the third output of your hiddevice-p node to the function node
  2. Add a FlowFuse Dashboard UI LED widget to the first output of the function
    • Configure LED colors: 1=Green, 2=Yellow, 3=Red
  3. Add a FlowFuse Dashboard text widget to the second output
    • This will display the connection status text
Example Flow
See the included examples/getStarted.json for a complete working example flow.
Important Notes
  • When using with input devices (keyboards, mice, etc.), be aware that the node may take exclusive control
  • For system input devices, prefer using path-based selection to ensure you connect to the right device
  • Multiple identical devices can be distinguished by their paths
For more information about node-hid, visit: https://github.com/node-hid/node-hid
Version: 1.3.1
Updated 1 year, 1 month ago
Rating: 4.0 1
  • hidconfig-p
  • gethiddevices-p
  • hiddevice-p
  • HID
  • FlowFuse
  • usbhid
  • usb-hid
  • barcodescanner
  • usb
