node-red-contrib-ur-robot 1.0.4
Node-red nodes for the dashboard-server interface and decoding of the rtde interface.
npm install node-red-contrib-ur-robot
installation
navigate to your node red directory
npm i node-red-contrib-ur-robot
usage
To use the dashboard server commands configure the node like in the picture below. If the msg.topic is disabled, the node sends the commands which is choosed in the dropdown. The command will be sent when any message triggers the node. https://user-images.githubusercontent.com/25501536/56346646-e8469400-61c2-11e9-830c-1ee97549d548.png
If you want to send the command via msg.topic, enable the option. Set the command in msg.topic of the trigger message. All commands are listed here: https://www.universal-robots.com/how-tos-and-faqs/how-to/ur-how-tos/dashboard-server-cb-series-port-29999-15690/ https://user-images.githubusercontent.com/25501536/56346710-0d3b0700-61c3-11e9-92ba-e22a45a1d9f8.png
To read the real time data exchange, a tcp node is required See the example configuration in the picture below: https://user-images.githubusercontent.com/25501536/56346792-322f7a00-61c3-11e9-8b25-a4cb57e938e4.png
Version: 1.0.4
Updated 8 years, 2 months ago
14 in the last week
  • dashboard-server
  • rtde-interface
  • universal
  • robots
  • realtime-data-interface
  • ur3
  • ur5
  • ur10
