node-red-contrib-uos-nats 1.4.19
Node-RED nodes for Weidmüller u-OS Data Hub. Read, write, and provide variables via NATS protocol with OAuth2 authentication. Features: Variable Key resolution, custom icons, example flows, and provider definition caching.
npm install node-red-contrib-uos-nats
Unofficial Node-RED Package for Weidmüller u-OS Data Hub
Read, write, and provide variables via NATS protocol using OAuth2 authentication. Optimized for high performance and real-time updates.
IMPORTANT: These nodes MUST run directly on the u-OS device (e.g. as a simplified App or Snap). The system's NATS server is NOT accessible from the outside (blocked by firewall/binding). You cannot use this package from a remote Node-RED instance (e.g. on your Laptop) to connect to the device.
Maintained by IoTUeli. Source: GitHub
Nodes Overview
Node Purpose
u-OS Config Central configuration for NATS connection and OAuth credentials.
Read Subscribe to variable changes from system providers (e.g. u_os_adm).
Write Send commands to change variables in other providers.
Provider Create your own provider to publish variables to the Data Hub.
u-OS Unified HTTP Interface for Variables & System Admin (Reboot, Networking, etc.).
Run the following command in your Node-RED user directory (usually ~/.node-red):
Restart Node-RED. The nodes will appear in the "Weidmüller DataHub" category.
Quick Start
1. Create OAuth Client (in u-OS)
  1. Open u-OS Web UI (Control Center → Identity & access → Clients).
  2. Click Add client.
  3. Name: nodered (example).
  4. Scopes: Select all hub.variables.* scopes.
  5. Copy Client ID and Client Secret.
2. Configure Node-RED
  1. Drag a Read node to the canvas.
  2. Click the pencil ✏️ next to Connection.
  3. Enter:
    • Host: IP of your u-OS device (e.g. 127.0.0.1 for local).
    • Client Name: Important! Give it a name (e.g. nodered).
    • Client ID / Secret: Paste from Step 1.
  4. Click Test connection.
3. Example Flow
Import this flow to test reading and writing immediately:
[{"id":"cdad2fa96dc6eeec","type":"datahub-input","z":"c221537c994b056a","name":"Read Zipcode","connection":"a0ba0e15c8dad779","providerId":"u_os_adm","manualVariables":"digital_nameplate.address_information.zipcode:2","triggerMode":"event","pollingInterval":"1000","x":190,"y":100,"wires":[["315d179d66bf9b93"]]},{"id":"315d179d66bf9b93","type":"debug","z":"c221537c994b056a","name":"Debug Output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":440,"y":100,"wires":[]},{"id":"a0ba0e15c8dad779","type":"uos-config","clientName":"nodered-client"}]
Node Usage
Read (DataHub Input)
Reads values from existing providers (like u_os_adm).
  • Provider ID: Name of the source provider.
  • Variables: Use Load Variables to browse and select variables.
    • New: Supports Multi-Select and Categorization (Grouped by prefix).
  • Trigger: "Event" (instant update) or "Poll" (interval).
  • Chunking (New): Automatically splits large requests (>100 variables) to prevent timeouts.
Write (DataHub Write)
Changes values in other providers.
  • Single Mode: Select a variable from the list. Send msg.payload = value.
  • Batch Mode: Select NO variable (clear selection). Send msg.payload as a FLAT JSON object: {"var_key": value}.
  • Strict Mode: Automatically handles Fingerprints for strict providers (e.g. u_os_sbm).
Provider (DataHub Output)
Publishes your own data to the Data Hub.
  • Provider ID: Name of your provider (e.g. my-app).
  • Auto-Discovery: Automatically creates variable definitions based on your input JSON structure.
  • Bi-Directional: Enable "Allow external writes" to receive commands from other apps.
u-OS (API Node)
The u-OS node provides a unified HTTP interface for both DataHub Variables and System Administration.
  • Mode: DataHub Variables
    • Alternative access to variables via HTTP (REST) instead of NATS.
    • Actions: Read, Write, List Providers, List Variables.
    • Useful for one-off requests or environments where NATS is restricted.
    • New: Variable Multi-Select and Grouping now supported.
  • Mode: System Administration
    • Manage the u-OS device itself.
    • Categories: System (Reboot), Network, Security, Logging.
    • Requirements: You must enable System Admin Access in the u-OS Config node.
  1. Host: IP address of the u-OS device (default: 127.0.0.1 for local Node-RED).
  2. Auth: Client ID and Client Secret (from u-OS Device Administration).
  3. Scopes:
    • Standard scopes for DataHub are active by default.
    • Check "Enable System Admin Access" to manage the system.
Performance & Optimization
  • HTTPS Agent: Secure connection handling (no global TLS override).
  • Chunking: Large variable lists are split into 100-item chunks for reliable reading.
  • Filter-on-Decode: High-speed filtering at the byte-level to save CPU.
⏱️ Benchmarking
You can verify the speed of your u-OS / NATS setup using the included benchmark flow.
  1. Import examples/benchmark-flow.json.
  2. Configure your credentials.
  3. Click the inject button.
  4. Check the Debug output for "Latency Result".
Expected Round-Trip-Time (RTT):
  • < 4ms: Excellent (Localhost / standard)
  • < 10ms: OK (High Load)
  • > 20ms: System overloaded or Slow Consumer bottleneck.
Troubleshooting
  • Provider not visible? Check Client ID and Scopes.
  • Status "cooldown"? The node is pausing after an error to protect the network.
  • Status "illegal ID"? You used a reserved name. Use nodered or similar.
  • Write not working? Ensure your OAuth client has hub.variables.readwrite scope.
  • Debug: Check the Node-RED "Debug" sidebar for error messages.
DISCLAIMER:
This is NOT an official product of Weidmüller Interface GmbH & Co. KG.
This package is maintained by IoTUeli as a community contribution.
Use at your own risk. No liability or warranty is assumed.
Version: 1.4.19
Updated 9 months, 3 weeks ago
Rating: 4.0 4
925 in the last week
  • uos-config
  • datahub-input
  • datahub-output
  • datahub-write
  • uos-api
  • nats
  • uos
  • u-os
  • weidmueller
  • weidmüller
  • data-hub
  • datahub
  • industrial
  • iot
  • automation
  • plc
  • variables
  • oauth2
  • flatbuffers
  • write
  • read
  • provider
