node-red-contrib-unifi-client 0.0.6
Nodes to access UniFi
npm install node-red-contrib-unifi-client
This project add some nodes to node-red, to interact with unifi from ubiquiti .
This project, is mainly a proof of concept of the library unifi-client, and so mainly reuse tested functions .
You can read nodes documentation here .
Requirements
  • Installed UniFi-Controller version v6 or newer
  • An unifi user, without 2FA*
*: 2FA is supported, but not adapted to automated usage .
Installation recommended
The recommended way to install this module is from the Node-RED GUI itself. Menu/manage palette/Install/search for unifi and then click install.
Main Nodes
unifi-raw-controller-request
Allow you to do all the request you want to unifi . The node will do the connection and other for you, and then return directly the result of the request in msg.payload
unifi-door-events
Check for events on Unifi access Doors, and send a message per event .
Can be used to trigger a workflow depending on who open the door .
unifi-access-unlock-relais
Ask to unlock a relais (doors for example)
Developpers / Contributing
Adding nodes to this library is pretty easy .
First of all, be sure to have a ready node-red environnement (follow install tutorial), then clone the repos and install it in node-red config directory with a local module npm i /home/thib3113/repo/ .
Then, you can create a new node, you can check the example of DoorEvents :
- create a ts file in src/nodes
  - create a classe extending Node
  - export a function that will call the function "registerNode"
- create an html file with the same name as the ts file (without the extension)
- configure the package.json node-red part to add your node
To do request to Unifi, feel free to read the documentation of unifi-client .
When you are ready, open a PR
Thank you
Version: 0.0.6
Updated 2 years, 7 months ago
7 in the last week
  • unifi-controller
  • unifi-door-events
  • unifi-raw-controller-request
  • unifi-get-access-devices
  • unifi-network-get-devices
  • unifi-network-get-active-clients
  • unifi-core-events
  • unifi-access-unlock-relais
  • iot
  • unifi
  • ubiquiti
  • unifi-controller
  • unifi-events
  • Ubiquiti Networks
  • ubnt
  • network
  • UDR
  • UDM
  • UDM pro
  • cloud-key
