node-red-contrib-unide-ppmp 1.1.2
The Production Performance Management Protocol (PPMP) is a communication protocol for exchanging production-related data between industrial automation systems. It helps improve efficiency, reduce downtime, and enhance product quality by providing a standa
npm install node-red-contrib-unide-ppmp
Node-RED Bosch Unide PPMP node
platform NPM npm
Pre-requisites
The Node-RED-PPMP requires Node-RED to be installed.
To install the stable version use the Menu - Manage palette option and search for node-red-unide-ppmp, or run the following command in your Node-RED user directory - typically ~/.node-red:
npm i node-red-contrib-unide-ppmp
The Production Performance Management Protocol (PPMP) is a standardized format for capturing production-related data to analyze the performance of production facilities. It enables monitoring systems to collect and evaluate key metrics of machines in the context of a production process by correlating the machine status with the currently produced parts and the process information.
PPMP is composed of three payload formats: measurement payload, message payload, and process payload. The measurement payload contains machine measurements such as temperature and the produced part, while the message payload can be used to send arbitrary messages like alerts.
The process payload contains data about the production process, such as the product recipe, the order of operations, and the machine parameters. The payload is transported via JSON object, facilitating integration with different backend systems.
Measurement Payload
The measurement message is the format to exchange simple (non-structured, non-complex ) measurement data. It also allows to transport multiple measurement data (eg. values over time), called 'series'.
Version 2
See schema
Example - Measurement v2
  "content-spec": "urn:spec://eclipse.org/unide/measurement-message#v2",
  "device": {
    "deviceID": "a4927dad-58d4-4580-b460-79cefd56775b"
  "measurements": [
      "ts": "2002-05-30T09:30:10.123+02:00",
      "series": {
        "$_time": [0, 23, 24],
        "temperature": [45.4231, 46.4222, 44.2432]
      "series": {
        "$_time": [0, 13, 26],
        "pressure": [52.4, 46.32, 44.2432]
Version 3
See schema
Example - Measurement v3
  "content-spec": "urn:spec://eclipse.org/unide/measurement-message#v3",
  "device": {
    "id": "a4927dad-58d4-4580-b460-79cefd56775b"
  "measurements": [
      "ts": "2023-02-01T19:15:28.607Z",
      "series": {
        "time": [0],
        "temp": [0.8493]
Machine Message Payload
The main purpose of the machine message format is to allow devices and integrators to send messages containing an interpretation of measurement data or status.
Version 2
See schema
Example Machine Message v2
  "content-spec": "urn:spec://eclipse.org/unide/machine-message#v2",
  "device": {
    "deviceID": "2ca5158b-8350-4592-bff9-755194497d4e"
  "messages": [
      "code": "190ABT"
Version 3
See schema
Example Machine Message v3
  "content-spec": "urn:spec://eclipse.org/unide/machine-message#v3",
  "device": {
    "id": "2ca5158b-8350-4592-bff9-755194497d4e"
  "messages": [
      "ts": "2023-02-01T19:44:58.969Z",
      "code": "testCode"
Process Message Payload
The process message is the format to exchange data out of discrete processes. It also allows to transport process information, part information and measurement data for each phase of the process
Version 2
See schema
Example Process Message v2
  "content-spec": "urn:spec://eclipse.org/unide/process-message#v2",
  "device": {
  "process": {
    "ts": "2023-02-01T19:48:30.150Z"
  "measurements": [
      "ts": "2023-02-01T19:48:30.150Z",
      "series": {
        "force": [0.8493, 0.566, 5455],
        "pressure": [0.8493, 0.566, 5455]
Version 3
See schema
Example Process Message v3
  "content-spec": "urn:spec://eclipse.org/unide/process-message#v3",
  "device": {
  "process": {
    "ts": "2023-02-01T19:47:17.170Z"
  "measurements": [
      "ts": "2023-02-01T19:47:17.170Z",
      "series": {
Example flow
See also Examples
        "id": "a151bd9d2a567181",
        "type": "tab",
        "label": "Example PPMP",
        "disabled": false,
        "info": "",
        "env": []
        "id": "f4987da60e67e217",
        "type": "inject",
        "z": "a151bd9d2a567181",
        "name": "multiple message",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "{\"force\":[0.8493,0.566],\"pressure\":[0.8493,0.566]}",
        "payloadType": "json",
        "x": 200,
        "y": 260,
                "c73720c4187d76f7",
                "433ef75572dd6a14"
        "id": "ded20c49c6b2dc12",
        "type": "inject",
        "name": "single message",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "{\"temp\":[0.8493]}",
        "x": 200,
        "y": 180,
                "c73720c4187d76f7"
        "id": "21e0ffafa3811e4c",
        "type": "inject",
        "name": "code message",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "testCode",
        "payloadType": "str",
        "x": 200,
        "y": 360,
                "b835d254a9e6f65b"
        "id": "c73720c4187d76f7",
        "type": "PPMP-Measurement",
        "version": "3",
        "deviceId": "testDevice",
        "inputs": 1,
        "outputs": 1,
        "x": 450,
        "y": 180,
                "257a4c628d82dd9a",
                "79891cd68a42aae3"
        "id": "433ef75572dd6a14",
        "type": "PPMP-Process",
        "version": "3",
        "inputs": 1,
        "outputs": 1,
        "x": 460,
        "y": 260,
                "4f6053be7196c47a",
                "79891cd68a42aae3"
        "id": "b835d254a9e6f65b",
        "type": "PPMP-Message",
        "version": "3",
        "inputs": 1,
        "outputs": 1,
        "x": 460,
        "y": 360,
                "7a0be859f0bdba49",
                "79891cd68a42aae3"
        "id": "4f6053be7196c47a",
        "type": "debug",
        "name": "debug two",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 670,
        "y": 260,
        "id": "257a4c628d82dd9a",
        "type": "debug",
        "name": "debug one",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 670,
        "y": 180,
        "id": "7a0be859f0bdba49",
        "type": "debug",
        "name": "debug three",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 670,
        "y": 360,
        "id": "79891cd68a42aae3",
        "type": "http request",
        "method": "POST",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "http://127.0.0.1:1880/ppmp",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 970,
        "y": 260,
                "08af9e81dc0a6fe2"
        "id": "08af9e81dc0a6fe2",
        "type": "debug",
        "name": "response debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "x": 1180,
        "y": 260,
        "id": "a4c8aed7859db94b",
        "type": "http in",
        "url": "/ppmp",
        "method": "post",
        "upload": false,
        "swaggerDoc": "",
        "x": 190,
        "y": 480,
                "25add09707dd429d",
                "11a67b1ff49701d5"
        "id": "25add09707dd429d",
        "type": "http response",
        "statusCode": "",
        "headers": {},
        "x": 370,
        "y": 480,
        "id": "11a67b1ff49701d5",
        "type": "debug",
        "name": "debug input",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 390,
        "y": 540,
Version: 1.1.2
Updated 4 years ago
License: apache-2.0
1 in the last week
  • ppmp
  • unide
  • bosch
