node-red-contrib-uk-national-rail 0.1.4
A Node-RED node to provide a list of upcoming train departures.
npm install node-red-contrib-uk-national-rail
Pre-requisites
To use this node you will require an API key from the UK National Rail Developers web site.
Install using the Manage Palette menu option, or manually run the following command in your Node-RED user directory - typically ~/.node-red
    npm i --save dceejay/node-red-contrib-uk-national-rail
Outputs
  • payload contains an array of upcoming train departure objects.
  • topic set to the station code of the station requested.
Inputs
  • station a station code string that can be used if one is not specified in the configuration. The configuration has precedence.
Version: 0.1.4
Updated 5 years, 3 months ago
7 in the last week
  • natrail
  • natRail-config
  • rail
  • train
  • timetable
