node-red-contrib-uk-ea-flood-warnings 0.0.3
Wrapper tp UK EA Flood Warnings API
npm install node-red-contrib-uk-ea-flood-warnings
Node-RED wrapper to the UK Environment Agency Real Time Flood-monitoring API
Use the manage palette option to install this node
This node allows you to run queries against the UK Environment Agency Flood Warning API
Use the configuration to select the mode. If floods are selected then All Flooded Areas will return all active flood alerts. If tides are selected then All Stations will return details and measurements for all tidal measurement stations.
Input
msg.payload is not required. The node needs to be configured to select an area. A list of available areas and tidal stations is automatically retrieved by the node, making use of the API.
You can override the area setting by setting msg.floodarea, which must be a comma separated string.
Output
The output is a json array on msg.payload. When running in flood mode and there are no flood alerts in the selected area then the array is empty.
Contributing
For simple typos and fixes please just raise an issue pointing out our mistakes. If you need to raise a pull request please read our contribution guidelines before doing so.
Copyright and license
Copyright 2018 IBM Corp. under the Apache 2.0 license.
Version: 0.0.3
Updated 7 years, 11 months ago
6 in the last week
  • uk-flood-warnings
  • flood
  • Soheel Chughtai
