node-red-contrib-ui-timelines-chart 0.1.9
A Node-RED widget node for showing the timelines chart.
npm install node-red-contrib-ui-timelines-chart
ui-timelines-chart
node-red
Pre-requisites
The node-red-contrib-ui-timelines-chart requires Node-RED Dashboard 2.10 to be installed.
Quick Start
To pull from docker hub:
docker pull sanlike0911/node-red-contrib-ui-timelines-chart:latest
Note: This node uses APIs that require at least Node-RED 0.19 and Node-RED Dashboard 2.10.
"ui-timelines-chart" node is a UI widget that can be used to display the timelines chart in the Node-RED dashboard.
This Node-Red module can not directly connect to Database.
  • Widget properties
    widget propertie
    • name
      Set the node name to be displayed in flow.
    • group
      Set the group to be displayed on the dashboard.
    • size
      Set the size on the dashboard.
    • label
      Set for the name to be displayed on the dashboard.
    • xAxis
      • tick format
        Set the tick format of the X-Axis.
        - YYYY-MM-DD HH:mm:ss
        - YYYY-MM-DD
        - HH:mm:ss
        - HH:mm
        - HH
        *ISO 8601 format
      • start date
        Set the start time of the X-Axis. If not set, select the first data.
      • end date
        Set the end time of the X-Axis. If not set, select the last data.
      • labels size[px]/color
        Set the font size[in pixels] and font color to X-Axis label. size: from 0 to 64(default:16)
    • yAxis
        Set the font size[in pixels] and font color to Y-Axis label. size: from 0 to 64(default:16)
    • tooltips
      • time format
        Set the time format of tooltips. See d3-time-format for available options.
    • format chart area
      • chart top margin[px]
        Set the top margin of the chart, in pixels. height: from 0 to 255(default:60)
      • chart height[px]
        Set the chart maximum height of each line, in pixels. height: from 1 to 255(default:60)
      • reset zoom label size[px]/color
        Set the font size[in pixels] and font color to reset zoom label. size: from 0 to 64(default:24)
    • options
      • enable animations
        Set whether to animate transitions.
      • enable date marker(now)
        Set whether to display the current date of the vertical line.
      • enable forward input messages
        Set whether to forward input messages to output.
    • legends
      Set the color and value to be displayed on the chart.
  • Input items
    An array of Items is passed in by msg.payload. It consists of objects containing the following properties.
    [Data syntax]
        dataItems:[
                group: "group1name",
                data: [
                    label: "label1name",
                    data: [
                        timeRange: [<date>, <date>],
                        val: <val: number (continuous dataScale) or string (ordinal dataScale)>
                        val: <val>
                    label: "label2name",
                    data: [...]
                group: "group2name",
                data: [...]
        settings:{
            xAxis:{
                tickFormat: <val: string (date time[default:YYYY-MM-DD HH:mm:ss])>,
                startDateTime: <date>,
                endDateTime: <date>,
                labelsFontSize: <val: number (from 0 to 64[default:16])>
                labelsColor: <val: string (from #000000 to #ffffff[default:#000000])>
            yAxis:{
            tooltips:{
              timeFormat: <val: string (d3-time-format[default:%Y-%m-%d %H:%M:%S])>,
            chart:{
              topMargin: <val: number (from 0 to 255[default:60])>
              height: <val: number (from 1 to 255[default:60])>
              resetZoom:{
                  labelFontSize: <val: number (from 0 to 64[default:24])>
                  labelColor: <val: string (from #000000 to #ffffff[default:#000000])>
              lineColors <{val: string (from #000000 to #ffffff[default:#000000]), val: string (label name)}>,
            options:{
              enableAnimations: <boolean>,
              enableDateMarker: <boolean>,
              forwardInputMessages: <boolean>
    priority: (msg.payload.settings > node property settings)
npm-scripts
There are some npm-scripts to help developments.
  • npm install - Install the testing environment in your project.
  • npm run build - Make ./data/my-node directory from the src directory and Install the my-node in Node-RED.
  • npm run start - Start Node-RED. "http://localhost:1880"
file list
[root]
│  package.json
│  README.md
│  tsconfig.json
├─data -> `Node-Red work files`
│  ├─my-node -> `project files` The resource files and built files should be placed here.
│  │  │  package.json
│  │  └─nodes -> The resource files and built files should be placed here.
│  └─node_modules
├─dist -> `The project built files`
├─examples -> `node-RED flow files`
├─figs
└─src
    └─nodes -> project files
        ├─icons
        ├─lib
        ├─locales
        │  ├─en-US
        │  └─ja
        └─test
Version: 0.1.9
Updated 4 years, 7 months ago
Rating: 4.4 5
66 in the last week
  • dashboard
  • status chart
  • timeline chart
  • chart
  • widget
