node-red-contrib-ui-ping 1.0.0
A Node-RED node which takes input and pings a remote server.
npm install node-red-contrib-ui-ping
node-red-configurable-ping
This is a modification of the node-red-configurable-ping node. The update is that the payload is now a boolean so that is easier to use with dashboard nodes.
npm install node-red-configurable-ping
  • Pings a machine and returns the trip time in ms. Ping time is returned in msg.time. Returns boolean false if no response received within 5 seconds, or if the host is unresolveable.
  • A boolean will be retured in msg.payload.
  • Will perform ping on any input.
  • You may override the host set in the configuration by passing in a value in msg.host.
  • For legacy reasons, the node will output the host as msg.topic (the original node-red-node-ping does it this way).
  • Any incomming data will be passed on to the output.
    • Incoming msg.payload data will be outputted as msg._payload (as the new msg.payload will contain the result of the ping).
    • Incoming msg.topic data will be outputted as msg._topic (as the new msg.topic will contain the the host).
Changes over node-red-contrib-advanced-ping
Ability to set ping options (timeout and number of requests). The defaults are:
  • 5 seconds timeout
  • 1 ping request
Version: 1.0.0
Updated 5 years, 2 months ago
License: Apache
Rating: 5.0 2
41 in the last week
  • ui ping
  • node-red-ping
  • node-red-configurable-ping
  • nodered
  • nodered ping
  • nodered configurable ping
  • ping
  • ui ping
