node-red-contrib-ui-navbar 1.0.11
A custom Node-RED Dashboard 2.0 navigation bar widget
npm install node-red-contrib-ui-navbar
A custom Node-RED Dashboard 2.0 widget that provides a simple, configurable navigation bar (navbar).
Each button in the navbar can send a payload and optionally trigger a page change when used with ui-control.
From your Node-RED user directory (typically ~/.node-red):
Restart Node-RED after installation.
  1. Drag the UI Navbar node into your flow.
  2. Open the node’s Properties panel.
  3. Use the Add Button option to add one or more buttons.
    • Each button has:
      • Label → Text displayed on the navbar.
      • Value → Payload sent when the button is clicked.
  4. Deploy your flow.
  5. The navbar will appear on every page in your Dashboard 2.0.
When a button is clicked, the node outputs a message like:
{ "payload": "I1O1", "topic": "ui-navbar" }
This can be connected to a ui-control node if you want the button to switch pages.
Example Flow
An example flow is provided in examples/basic.json.
To use it:
  1. In the Node-RED editor, click the hamburger menu → Import → Clipboard.
  2. Paste the contents of examples/basic.json.
  3. Deploy.
  4. You’ll see a demo navbar with two sample buttons (I1O1, I2O1).
Node-RED Scorecard Compliance
  • License: MIT
  • Bugs URL supplied
  • Package name follows guidelines
  • Node-RED keyword set
  • Supported Node-RED Version: >=3.0.0
  • Node.js Version: >=14
  • Package uses a unique name
  • Nodes: ui-navbar
  • Nodes have unique names: Yes
  • Nodes have examples: Yes (examples/basic.json)
Roadmap
  • Improve Add Button behavior in the Properties panel (dynamic list UI like other Dashboard nodes).
  • Styling options for colors, active state, and alignment.
MIT
Version: 1.0.11
Updated 1 year, 2 months ago
Rating: 1.0 1
631 in the last week
  • ui-navbar
  • node-red-contrib
  • dashboard
  • navbar
  • ui
