node-red-contrib-ui-led2 0.4.22
A simple LED status indicator for the Node-RED Dashboard
npm install node-red-contrib-ui-led2
Node-RED UI LED
Examples Image
The node uses msg.payload's value to determine status. By default:
  • msg.payload === true - Green
  • msg.payload === false - Red
  • no msg received yet or msg.payload !== true and msg.payload !== false - Gray
New in this variant: The node can not only use values from msg.payload to determine the status, elements of an object can also be specified (e.g. msg.payload.state).
To install the node run the following from your Node-RED user directory (~/.node-red):
Or install the node from the Palette section of your Node-RED editor by searching by name (node-red-contrib-ui-led).
Aesthetics
There are a number of options when it comes to the node's aesthetics.
By default the LED itself will grow and shrink to fit the vertical height of the space it is locked to, auto-size to fit the group if marked `auto`. Sizes
Most other customization happens in the Edit panel, which includes a preview so you can tweak to your heart's content.
Edit panel
Custom Statuses
Although true => Green and false => Red is the default, one can map other payload values to any color.
To customize the mappings open the node's configuration panel and scroll to the Colors for Values list.
Colors for Values Image
To add a value mapping press the +Color button at the bottom of the list.
Next fill in a color in a CSS format (color name, hex, rgb, rgba...), select the value type (string, boolean...) and fill in an appropriate value.
Similarly existing Value => Color maps can be modified.
Finally to delete a mapping simply press the X button on the far right!
Custom Statuses in msg
By enabling Allow Color For Value map in msg in a node that node will use dictionaries passed via msg.colorForValue to override any previous color to value mappings.
The format should be value => color, ie an object whose key values return color values.
Example:
msg.colorForValue = {}
msg.colorForValue[true] = 'purple'
msg.colorForValue[false] = 'orange'
Further Examples
To see usages already set up check out the examples included with the project by using Import in your Node-RED editor!
FOSSA Status
Thanks to
Version: 0.4.22
Updated 4 months ago
221 in the last week
  • ui_led2
  • led2
  • dashboard
  • ui
