node-red-contrib-ui-led-fork 0.3.1
A simple LED status indicator for the Node-RED Dashboard
npm install node-red-contrib-ui-led-fork
Node-RED UI LED
dependencies dev-dependencies optional-dependencies peer-dependencies
Examples Image
The node uses msg.payload's value to determine status. By default:
  • msg.payload === true - Green
  • msg.payload === false - Red
  • no msg received yet or msg.payload !== true and msg.payload !== false - Gray
To install the node run the following from your Node-RED user directory (~/.node-red):
Or install the node from the Palette section of your Node-RED editor by searching by name (node-red-contrib-ui-led).
Custom Statuses
Although true => Green and false => Red is the default, one can map other payload values to any color.
To customize the mappings open the node's configuration panel and scroll to the Colors for Values list.
Colors for Values Image
To add a value mapping press the +Color button at the bottom of the list.
Next fill in a color in a CSS format (color name, hex, rgb, rgba...), select the value type (string, boolean...) and fill in an appropriate value.
Similarly existing Value => Color maps can be modified.
Finally to delete a mapping simply press the X button on the far right!
Custom Statuses in msg
By enabling Allow Color For Value map in msg in a node that node will use dictionaries passed via msg.colorForValue to override any previous color to value mappings.
The format should be value => color, ie an object whose key values return color values.
Example:
msg.colorForValue = {};
msg.colorForValue[true] = "purple";
msg.colorForValue[false] = "orange";
General Example Usage
This example sets up an MQTT broker and topic with two buttons to simulate a true and false status value. To see more examples please run the project in the example folder:
[{"id":"d3b3123c.3700d","type":"tab","label":"Sensors","disabled":false,"info":""},{"id":"2fa28c61.b659f4","type":"tab","label":"Debug","disabled":false,"info":""},{"id":"e120d946.46fa68","type":"mqtt-broker","z":"","name":"Node-RED","broker":"localhost","port":"1883","clientid":"Node-RED","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"5ee52ff4.c9bcd","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false},{"id":"e6d3e1d1.040fe","type":"ui_tab","z":"","name":"Debug","icon":"dashboard","disabled":false,"hidden":false},{"id":"d2a16e71.43f47","type":"ui_group","z":"","name":"Home","tab":"5ee52ff4.c9bcd","disp":true,"width":"6","collapse":false},{"id":"703bff68.9236e","type":"ui_base","theme":{"name":"theme-light","lightTheme":{"default":"#0094CE","baseColor":"#0094CE","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#097479","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#0094CE","value":"#0094CE","edited":false},"page-titlebar-backgroundColor":{"value":"#0094CE","edited":false},"page-backgroundColor":{"value":"#fafafa","edited":false},"page-sidebar-backgroundColor":{"value":"#ffffff","edited":false},"group-textColor":{"value":"#1bbfff","edited":false},"group-borderColor":{"value":"#ffffff","edited":false},"group-backgroundColor":{"value":"#ffffff","edited":false},"widget-textColor":{"value":"#111111","edited":false},"widget-backgroundColor":{"value":"#0094ce","edited":false},"widget-borderColor":{"value":"#ffffff","edited":false},"base-font":{"value":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"}},"angularTheme":{"primary":"indigo","accents":"blue","warn":"red","background":"grey"}},"site":{"name":"Node-RED Dashboard","hideToolbar":"false","allowSwipe":"false","lockMenu":"false","allowTempTheme":"true","dateFormat":"DD/MM/YYYY","sizes":{"sx":48,"sy":48,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"f07f2284.66882","type":"ui_group","z":"","name":"Debug","tab":"5ee52ff4.c9bcd","disp":true,"width":"6","collapse":false},{"id":"84a49aa6.ece8f8","type":"mosca in","z":"d3b3123c.3700d","mqtt_port":1883,"mqtt_ws_port":8080,"name":"","username":"","password":"","dburl":"","x":138.5,"y":63,"wires":[[]]},{"id":"4e1b0ebf.b8849","type":"mqtt out","z":"2fa28c61.b659f4","name":"","topic":"/sensors/example","qos":"1","retain":"","broker":"e120d946.46fa68","x":503.5,"y":68,"wires":[]},{"id":"91e93093.b69b9","type":"template","z":"2fa28c61.b659f4","name":"Connected","field":"payload","fieldType":"msg","format":"json","syntax":"plain","template":"{\n    \"connectionStatus\": true\n}","output":"json","x":277.5,"y":46,"wires":[["4e1b0ebf.b8849"]]},{"id":"d5778615.363838","type":"template","z":"2fa28c61.b659f4","name":"Disconnected","field":"payload","fieldType":"msg","format":"json","syntax":"plain","template":"{\n    \"connectionStatus\": false\n}","output":"str","x":287.5,"y":99,"wires":[["4e1b0ebf.b8849"]]},{"id":"11fb0eab.b93991","type":"ui_button","z":"2fa28c61.b659f4","name":"","group":"f07f2284.66882","order":3,"width":0,"height":0,"passthru":false,"label":"Connect","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":105.5,"y":46,"wires":[["91e93093.b69b9"]]},{"id":"30e579e9.a240a6","type":"ui_button","z":"2fa28c61.b659f4","name":"","group":"f07f2284.66882","order":2,"width":0,"height":0,"passthru":false,"label":"Disconnect","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":95,"y":99,"wires":[["d5778615.363838"]]},{"id":"2de44e18.457882","type":"ui_led","z":"d3b3123c.3700d","group":"d2a16e71.43f47","name":"Connected","order":0,"label":"Connected","x":668,"y":123,"wires":[]},{"id":"f692216.3bbe7e","type":"function","z":"d3b3123c.3700d","name":"Connected Status","func":"if (typeof msg.payload == 'object' && \n    msg.payload.connectionStatus === true) {\n    msg.payload = true;\n} else {\n    msg.payload = false;\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":483,"y":123,"wires":[["2de44e18.457882"]]},{"id":"97e1b56b.41ae98","type":"json","z":"d3b3123c.3700d","name":"","property":"payload","action":"","pretty":false,"x":313,"y":123,"wires":[["f692216.3bbe7e"]]},{"id":"7e8d71cc.8cc83","type":"mqtt in","z":"d3b3123c.3700d","name":"","topic":"/sensors/example","qos":"2","broker":"e120d946.46fa68","x":142,"y":124,"wires":[["97e1b56b.41ae98"]]}]
Version: 0.3.1
Updated 7 years, 2 months ago
Rating: 3.3 3
6 in the last week
  • ui_led
  • led
  • dashboard
  • ui
