node-red-contrib-ui-editor 0.0.1
A Node-RED dashboard ui node for block-style editor.
npm install node-red-contrib-ui-editor
A Node-RED dashboard ui node for block-style editor implemented with Editor.js.
Example
Either use the Editor - Menu - Manage Palette - Install option, or run the following command in your Node-RED user directory (typically ~/.node-red) after installing Node-RED-dashboard.
npm i node-red-contrib-ui-editor
Requirements
Node-RED v19.4 or greater Node-RED-dashboard v2.13.0 or greater
ui_editor widget displays an interactive block-style editor implemented by Editor.js on the Node-RED dashboard.
You can add new block by clicking add button (add button).
inline tool
A block can tuned by clicking tune button (tune button).
inline tool
Inline tools can be invoked by selecting text.
inline tool
https://user-images.githubusercontent.com/30289092/233401827-e945885f-ae4b-4caf-bb67-37abb6a98fb9.mp4
The editor supports following plugins for blocks and inline tools:
  • @editorjs/paragraph - text block tool
  • @editorjs/header - header block tool
  • @editorjs/quote - quotes block tool
  • @editorjs/warning - warning tool for notification or appeals
  • @editorjs/delimiter - delimiter tool
  • @editorjs/nested-list - multi-level lists tool
  • @editorjs/checklist - checklists tool
  • @editorjs/simple-image - image reference tool
  • @editorjs/table - table tool
  • @editorjs/code - tool for code examples
  • @editorjs/raw - tool for including raw HTMLs
  • editorjs/marker - tool for highliting text fragments
  • editorjs/inline-code - tool for marking code fragments
  • editorjs/underline - tool for underlining text fragments
  • editorjs/text-variant-tune - block tune for text variants`
Editor content can be controlled by including the following commands in the node's input message.
Example
There are examples that you can import from the Node-RED editor menu:
Import > Examples > node-red-contrib-ui-editor
Version: 0.0.1
16 in the last week
  • ui_editor
  • node-red-dashboard
  • dashboard
  • editor
