node-red-contrib-ui-digital-clock 1.0.0
A digital clock for the Node-RED Dashboard.
npm install node-red-contrib-ui-digital-clock
Open Node-RED and select Manage palette from the menu to open the Palette Manager. Go to the Install tab, search for node-red-contrib-ui-digital-clock and click install.
Alternatively, you can run the following command in your Node-RED user directory (typically ~/.node-red):
npm i node-red-contrib-ui-digital-clock
Example
[{"id":"c09db1ba6ac377de","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"37ec70937bed02a4","type":"ui_digital_clock","z":"c09db1ba6ac377de","name":"","group":"5c79b643fcd37cad","order":0,"width":"6","height":"2","x":710,"y":340,"wires":[]},{"id":"105daf8d29a83f81","type":"inject","z":"c09db1ba6ac377de","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":490,"y":340,"wires":[["37ec70937bed02a4"]]},{"id":"5c79b643fcd37cad","type":"ui_group","name":"Standard","tab":"f4a9e911ba044f38","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"f4a9e911ba044f38","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
MIT
Miscellaneous
Also take a look at my other dashboard items:
node-red-contrib-ui-clock
A simple analog clock for the Node-RED Dashboard.
node-red-contrib-ui-digital-display
A digital display, with adjustable number of digits and decimals, for the Node-RED Dashboard.
Version: 1.0.0
Updated 4 years, 11 months ago
Rating: 5.0 3
53 in the last week
  • ui_digital_clock
  • clock
  • dashboard
  • time
  • ui
