node-red-contrib-ui-countdown-timer-switch 1.4.1
A ui countdown timer switch for the Node-RED Dashboard
npm install node-red-contrib-ui-countdown-timer-switch
A node-red-ui countdown timer switch for the Node-RED Dashboard.
You can install this node directly from the "Manage Palette" menu in the Node-RED interface.
Alternatively, run the following command in your Node-RED user directory - typically ~/.node-red on Linux or %HOMEPATH%\.nodered on Windows
Requirements
node-red v0.19 or above
node-red-dashboard v2.10.0 (v2.15.4 or above would be ideal)
Add a countdown-timer-switch-node to your flow. Open the dashboard, by default you will see four buttons. Each button has a label with a number that indicates how long the switch stays on (in minutes). Click one of those buttons and the switch will be on for the specific amount of time.
Input
The countdown can be activated via an incoming message if it has a property countdown. The value of msg.countdown must be a number in minutes. The switch will stay on for the specified amount of time. A msg.countdown with a value of 0 turns the switch off.
Size
You can leave it with a grid size of 'auto' but if you want to change that make sure it's at least 5x2 (you can make it smaller if you don't mind scrollbars though).
History
Find the changelog here.
Donate
You can donate by clicking the following link if you want to support this free project:
Version: 1.4.1
Updated 4 years, 2 months ago
Rating: 4.8 4
31 in the last week
  • ui_countdown_timer_switch
  • countdown-timer-switch
  • switch
  • timer
  • dashboard
  • frontend
  • iot
