node-red-contrib-uhppoted 1.1.14
A set of nodes for the UHPPOTE Wiegand Access Controller
npm install node-red-contrib-uhppoted
build platform npm version NPM
Node-RED module that implements an API for interacting with a UHPPOTE TCP/IP Wiegand access controller board. The API supports controller and card management as well support for controller events.
In The Wild
Release Notes
PLEASE NOTE
As of v1.1.8 the controllers list in the config is being deprecated in favour of using a controller object in the input message payload to a uhppoted node. The legacy implementation will be supported until at least the next major release but you are encouraged to update your flows.
For more information see the controllers section.
Current Release
1.1.14 - 2026-09-17
  1. Migrated repository from github to codeberg.
  2. Updated to NodeRED 5.07.
  3. Implemented uhppoted-set-firstcard node to manage door first-card control modes.
  4. Added first-card privileges to the get-card, get-card-at-index and put-card nodes.
  5. Added retry when ephemeral UDP port collides with broadcast port.
  6. Added retry when ephemeral TCP port collides with destination port.
Requirements:
  • node‑red version 2.2.3+
  • node.js version 14.18.3+
To install the stable version use the Menu - Manage palette option and search for node-red-contrib-uhppoted, or run the following command in your Node-RED user directory (e.g. ~/.node-red on MacOS and Linux):
Restart your Node-RED instance and you should have the uhppoted nodes available in the palette.
If you want to try the development version from the node‑red‑contrib‑uhppoted codeberg repository:
cd ~/.node-red/node_modules
git clone https://codeberg.org/uhppoted/uhppoted-lib-node-red.git
cd node-red-contrib-uhppoted
npm install
Upgrading from v0.x
Please note that updating from node-red-contrib-uhppoted v0.x to v1.x is a breaking change. node-red-contrib-uhppoted v1.0 fixed node name conflicts with other NodeRED modules and unfortunately changing node names throughout requires a breaking change.
Please see:
Node Description
get‑devices Fetches a list of access controllers on the local LAN
get‑device Retrieves the information for a single access controller
set‑ip Sets the controller IP address, net mask and gateway address
get‑status Retrieves the current controller status
get‑time Retrieves the current controller date and time
set‑time Sets the controller date and time
get‑door‑control Retrieves the control configuration for a controller door
set‑door‑control Sets the control configuration for a controller door
open‑door Remotely opens a controller door
get‑card Retrieves a card record from a controller
get‑card-by-index Retrieves a card record from a controller by record number
put‑card Adds or updates a card record on a controller
delete‑card Deletes a card record from a controller
delete‑all‑cards Deletes all card records stored on a controller
get-time-profile Retrieve a time profile from a controller
set-time-profile Defines a time profile on a controller
clear-time-profiles Deletes all time profiles defined on a controller
clear-task-list Clears a controller task list
add-task Adds a new task to a controller's task list
refresh-task-list Refreshes a controller task list
record-special-events Enables or disables door events
get‑event‑index Retrieves the current event index from a controller
set‑event‑index Sets the current event index on a controller
get‑event Retrieves a single event from a controller
set-pc-control Delegates access control to an offboard application
set-interlock Sets the controller door interlock mode
activate-keypads Activates/deactivates the reader access keypads
set-door-passcodes Sets the supervisor keypad passcodes for a door
get-antipassback Retrieves the controller anti-passback mode
set-antipassback Sets the controller anti-passback mode
set-firstcard Sets the first-card configuration for a controller managed door
restore-default-parameters Resets a controller to the manufacturer default configuration
listen Establishes a listening connection for controller events
All nodes take a message with JSON object payload as input and send a message with a JSON object payload as output.
The nodes can (optionally) accept a configuration that overrides the default settings:
Description Default
timeout Request execution timeout (in milliseconds) 5000
bind UDP address to bind to for requests 0.0.0.0
broadcast UDP address for broadcast requests 255.255.255.255
listen UDP address:port on which to listen for events 0.0.0.0:60000
controllers List of controller specific IPv4 address:port overrides for systems where a controller is either not located on the same LAN (i.e. cannot receive or respond to UDP broadcasts) or where directed UDP messages are preferred. (none)
debug Enables logging of request/response messages to the console false
Controllers
All nodes (other than get-devices) expect a controller in the input message payload. v1.1.8+ supports two formats for the controller:
  • the (legacy) implementation which expects the controller serial number as a device ID:
    "deviceId": 405419896
  • the revised implementation which expects the controller as an object:
    "controller": {
        "id": 405419896,
        "address": "192.168.1.100",
        "protocol": "tcp"
- id: controller serial number
- address: controller IPv4 address (optional)
- protocol: 'udp' or 'tcp' (optional)
Defaults to UDP broadcast transport if the address is null or the protocol is not 'tcp'.
NOTE:
The legacy implementation will be supported until at least the next major release but any future enhancements will expect the controller object and you are encouraged to update your flows accordingly.
In most cases, this is simply a matter of updating the input message payload to a uhppoted node from e.g.:
    "deviceId": 405419896,
    "cardNumber": 10058400
to
    "controller": {
        "id": 405419896
Examples
The node‑red‑contrib‑uhppoted codeberg repository includes a set of basic examples that demonstrate the usage of each node.:
Node Description
1‑get‑devices Example flow for the get‑devices node
2‑get‑device Example flow for the get‑device node
3‑set-ip Example flow for the set‑ip node
4‑event-listener Example flow for the listen. get-listener and set‑listener nodes
5‑get-status Example flow for the get‑status node
6‑time Example flow for the get‑time and set‑time nodes
7‑doors Example flow for the get‑door‑control, set‑door‑control, open‑door, activate-keypads, set-interlock, set-door-passcodes, get-antipassback, set-antipassback and set-firstcard nodes
8‑cards Example flow for the get‑cards, get‑card, get‑card‑by‑index, put‑card, delete‑card and delete‑cards nodes
9-time-profiles Example flow for the get-time-profile, set‑time-profile and clear-time-profiles nodes
10-tasklist Example flow for the clear-task-list, add-task and refresh-task-list nodes
11-events Example flow for the record-special-events, get‑event‑index, set‑event‑index and get‑event nodes
12-set-pc-control Example flow for the set-pc-control node
13-restore-default-parameters Example flow for the restore-default-parameters node
Issues and Feature Requests
Please create an issue in the node‑red‑contrib‑uhppoted codeberg repository.
MIT
Version: 1.1.14
Updated 1 month, 3 weeks ago
78 in the last week
  • uhppoted-config
  • uhppoted-get-devices
  • uhppoted-set-ip
  • uhppoted-get-time
  • uhppoted-set-time
  • uhppoted-get-door-control
  • uhppoted-set-door-control
  • uhppoted-get-listener
  • uhppoted-set-listener
  • uhppoted-record-special-events
  • uhppoted-get-status
  • uhppoted-get-cards
  • uhppoted-get-card
  • uhppoted-get-card-by-index
  • uhppoted-put-card
  • uhppoted-delete-card
  • uhppoted-delete-all-cards
  • uhppoted-get-time-profile
  • uhppoted-set-time-profile
  • uhppoted-clear-time-profiles
  • uhppoted-add-task
  • uhppoted-clear-task-list
  • uhppoted-refresh-task-list
  • uhppoted-get-event-index
  • uhppoted-set-event-index
  • uhppoted-open-door
  • uhppoted-set-pc-control
  • uhppoted-set-interlock
  • uhppoted-activate-keypads
  • uhppoted-set-door-passcodes
  • uhppoted-get-antipassback
  • uhppoted-set-antipassback
  • uhppoted-set-firstcard
  • uhppoted-restore-default-parameters
  • uhppoted-listen
  • uhppote
  • Wiegand
  • access control
