node-red-contrib-typeform-webhook 1.2.0
A NodeRED node that receive new Typeform submission a output an opiniated object
Install from npm
npm install node-red-contrib-cloud-firestore
Install from the palette manager
Config
Path
This is the path that will be listening to incoming webhook. It must be identical (but without the host part) to the one you give Typeform.
Setup a webhook in Typeform
Go to your Typeform workspace, open a form and go to the Connect header, then Webhooks tab. Click Add a webhook and give your NodeRED domain followed by the path you set in your node.
You can get more infos on the webhook API in the official documentation
Good practice
This node will output a single object containing all the answers with their reference as key. To get a usable object, don't forget to set reference in all your questions in Typeform
