node-red-contrib-tuyapi-cloud 0.2.0
TuyaSmart Device Cloud API Node-RED module
npm install node-red-contrib-tuyapi-cloud
NPM version
This module allows users to control and query Tuya Smart Devices using Node-RED through the Tuya Cloud API. It uses the @tuyapi/cloud library to communicate with the Tuya Cloud API.
In order to setup the plugin you will need to obtain the credentials to talk to the API cloud service. Obtaining keys for the API (additional parameters secret2 and certSign are required) involves disassembling obtained an APK file (either official app or generated "demo" app from iot.tuya.com). For details see tuya-sign-hacking repo.
Pre-requisites
The Node-RED-Dashboard requires Node-RED to be installed.
Restart your Node-RED instance and you should have the tuya api cloud request node available in the palette.
Settings
Once you've added the node to your flow setting up the configuration requires the Tuya Smart login credentials (the same as the ones registered through the TuyaSmart app), in addition to setting region, API version, and API Credentials (Key, Secret, Secret2, Certificate Signature and Region).
Getting the Key, Secret, Secret2 and Certificate Signature will require a bit of work documented at the tuya-sign-hacking repo.
Development
  1. After cloning, run npm install
  2. To build the TypeScript source for use in Node-RED run npm run build
Version: 0.2.0
Updated 8 years ago
Rating: 1.0 1
16 in the last week
  • tuyapi-cloud-configuration
  • tuyapi-cloud-request
  • tuya
