node-red-contrib-tuya-smart 1.2.0
Nodes to get data from tuya smart devices (like smart plugs, power strips, bulbs, ...).
npm install node-red-contrib-tuya-smart
tuya-smart
Build Status npm version
Input nodes to interface with smart plugs, bulbs, ... from tuya. Makes use of the tuyapi library. Check out their great guide on how to get your device id/device key out of the Tuya Smart/Smart Life app to get started. Once you got these device credentials, you will be able to configure and use this input node for NodeRED. The tuya devices are sold under different names like Gosund, BlitzWolf, Teckin, Meross, Homecube, ... Check out the general discussion regarding the tuya api and compatibility.
Connecting nodes
Connected nodes and output format
Input node with input and output format
powerstrip input node with input and output format
tuya 3-socket powerstrip outputs explained
You can install the package from the public npm registry using npm or the tooling provided by the NodeRED-GUI. Check out the NodeRED guide on adding nodes.
Development - how to build
You should be able to build the nodes executing
npm install
npm run-script build
To test them I use docker and mount the dist directory to /data/nodes like this docker run -it --name tuya-test-container -p 1880:1880 -v $(pwd)/dist/lib:/data/nodes nodered/node-red-docker. Be aware that by using this shortcut you have to ensure the dependencies of the nodes inside the container have to be installed manually docker exec -it tuya-test-container bash -c 'cd /data && npm i [email protected] --upgrade'.
Version: 1.2.0
Updated 8 years, 3 months ago
Rating: 3.0 2
56 in the last week
  • tuya
  • tuya-smart
  • powerplug
  • smart-home
