node-red-contrib-turbo 1.0.11
Ensemble d'outils utilitaires pour Node-RED
npm install node-red-contrib-turbo
Node-RED Contrib Turbo
A collection of utility nodes for Node-RED that simplify common message manipulation and value assignment tasks.
Available Nodes
turbo-ts
Execute TypeScript code with full Node-RED context and modern JavaScript features.
  • Script: TypeScript code editor with Monaco syntax highlighting
  • Outputs: Number of outputs (1-10)
  • Execution Mode: Function mode (faster but less secure) or VM mode (safer)
Available Context
The following variables are automatically available in your TypeScript code:
Variable Type Description Example
msg any Current message object msg.payload, msg.topic
node Node Current node instance node.log('info'), node.warn('warning')
RED NodeAPI Node-RED API RED.util.getSetting()
global any Global context global.get('config')
env object Environment variables env.get('API_KEY'), env.get('DATABASE_URL')
fs Promise<fs> File system (promises) await fs.readFile('file.txt')
path path Path utilities path.join('/home', 'user')
os os Operating system os.hostname(), os.platform()
crypto crypto Cryptography crypto.randomUUID()
util util Node utilities util.promisify()
Buffer Buffer Buffer constructor Buffer.from('text')
fetch fetch HTTP client await fetch('https://api.com')
process process Process information process.env, process.version
Usage Examples
Simple data transformation:
// Transform payload data
const data = msg.payload;
msg.payload = {
    processed: true,
    timestamp: new Date().toISOString(),
    data: data.map(item => item.name.toLowerCase())
HTTP API call with environment variables:
// Get API credentials from environment
const apiKey = env.get('API_KEY');
const baseUrl = env.get('API_BASE_URL') || 'https://api.example.com';
// Make authenticated request
const response = await fetch(`${baseUrl}/users/${msg.payload.userId}`, {
    headers: {
        'Authorization': `Bearer ${apiKey}`,
        'Content-Type': 'application/json'
const userData = await response.json();
return {
    ...msg,
    payload: userData,
    statusCode: response.status
File operations:
// Read configuration file
const configPath = path.join(process.cwd(), 'config', 'app.json');
const configData = await fs.readFile(configPath, 'utf8');
const config = JSON.parse(configData);
// Log system information
node.log(`Running on ${os.platform()} ${os.arch()}`);
node.log(`Node.js version: ${process.version}`);
return {
    ...msg,
    payload: {
        config,
        system: {
            platform: os.platform(),
            hostname: os.hostname(),
            nodeVersion: process.version
Multiple outputs:
// Process message and route to different outputs
const outputs = [];
if (data.type === 'user') {
    outputs[0] = { ...msg, payload: data }; // User output
    outputs[1] = null; // No admin output
} else if (data.type === 'admin') {
    outputs[0] = null; // No user output
    outputs[1] = { ...msg, payload: data }; // Admin output
return outputs;
  • ✅ Full TypeScript support with Monaco editor (VS Code editor)
  • ✅ Async/await ready - code runs in async function
  • ✅ Rich context - Access to Node-RED, Node.js APIs, and environment variables
  • ✅ Multiple execution modes - Function (fast) or VM (secure)
  • ✅ Multiple outputs - Support for 1-10 outputs with routing logic
  • ✅ Monaco editor - Syntax highlighting, IntelliSense, error detection
  • ✅ Error handling - Comprehensive error reporting and debugging
  • ✅ TypeScript compilation - Real-time TypeScript to JavaScript compilation
Editor Improvements
  • Monaco Editor Integration: Uses the same editor as VS Code
  • TypeScript Validation: Smart error filtering for Node-RED context
  • Auto-completion: IntelliSense for all available context variables
  • Syntax Highlighting: Full TypeScript syntax highlighting
  • Error Suppression: Filters out false-positive errors for await usage
turbo-set
Versatile node that allows setting message property values from different sources: paths, static values, or templates.
  • Target Path: Destination path (ex: payload, result[0].value)
  • Source Type: Type of data source
  • Source Path: Source path (visible for Message Path)
  • Content: Static value (visible for JSON/Text Value)
Source Types
Type Description Interface Example
Message Path Sets value from message path Source Path field payload.user.name, data.items[0]
JSON Value Static JSON automatically parsed Monaco JSON editor {"key": "value", "array": [1, 2, 3]}
JSON Template JSON with interpolated templates Monaco JSON editor {"user": "{{payload.name}}", "id": {{data.id}}}
Text Value Static text without processing Monaco text editor Hello World, Configuration complete
Text Template Text with interpolated templates Monaco text editor Hello {{payload.name}}!, Status: {{data.status}}
Usage Examples
Set from path:
Target: payload
Source Type: Message Path
Source Path: data.user.name
→ Sets msg.payload = msg.data.user.name
Set static JSON:
Target: config
Source Type: JSON Value
Content: {"enabled": true, "retries": 3, "timeout": 5000}
→ Sets msg.config = JSON object
Set with JSON template:
Target: result
Source Type: JSON Template
Content: {"user": "{{payload.name}}", "count": {{data.items.length}}}
→ Sets msg.result = JSON object with interpolated variables
Set static text:
Target: status
Source Type: Text Value
Content: Processing completed successfully
→ Sets msg.status = string
Set with text template:
Target: message
Source Type: Text Template
Content: Hello {{payload.user}}, you have {{data.count}} messages
→ Sets msg.message = text with interpolated variables
  • ✅ Conditional interface based on selected source type
  • ✅ Monaco editor with syntax highlighting (JSON/text)
  • ✅ Support for nested paths and array indices
  • ✅ Templates with variable interpolation {{...}}
  • ✅ Automatic JSON parsing to JavaScript object
  • ✅ Error handling with detailed messages
  • ✅ 5 modes: Message Path, JSON/Text Value/Template
turbo-exec
Execute shell commands with configurable execution modes and timeout control.
  • Mode: Execution method (Exec or Spawn)
  • Timeout: Maximum execution time in seconds (1-300)
  • Script: Shell commands to execute with Monaco editor
Execution Modes
Mode Description Outputs Use Case
Exec Buffered execution, collects all output 1 output: {out, err, success, code} System commands, quick scripts
Spawn Streaming execution, real-time output 3 outputs: stdout, stderr, result Long-running processes, log monitoring
Examples
System Information (Exec mode):
uname -a
df -h
free -m
→ Returns complete system info in single result
Log Monitoring (Spawn mode):
tail -f /var/log/application.log
→ Streams log entries in real-time
Build Process (Spawn mode):
npm install
npm run build
npm test
→ Monitor build progress with real-time feedback
  • ✅ Two execution modes: buffered (exec) and streaming (spawn)
  • ✅ Configurable timeout protection (1-300 seconds)
  • ✅ Monaco editor with shell script syntax highlighting
  • ✅ Process cleanup on node shutdown
  • ✅ Cross-platform support (Windows/Linux/macOS)
  • ✅ Real-time output streaming in spawn mode
  • ✅ Comprehensive error handling and reporting
Security Notes
  • Commands run with Node-RED process permissions
  • Validate input to prevent command injection
  • Use timeout to prevent runaway processes
  • Consider restricted shells for untrusted input
MIT
Version: 1.0.11
Updated 1 year, 3 months ago
  • turbo-set
  • turbo-exec
  • turbo-ts
  • exec
  • bash
  • script
  • typescript
  • utilities
  • tools
  • turbo
