node-red-contrib-tumblr 0.1.2
Node-RED node to talk to Tumblr
Node-RED node to talk to Tumblr. Currently supports posting of photos to the specified blog.
npm install node-red-contrib-tumblr
In order to use this node you will need to authenticate with Tumblr to allow access to your blogs. This is done in the node settings.
You can specify which blog you would like to post to in the node settings or by setting msg.blog
Tumblr photo out node
Posts the photo in msg.payload
to the blog name set it the node configuration.
