node-red-contrib-ttl 1.0.0
A Node-RED node for timing and killing stale messages.
npm install node-red-contrib-ttl
A Node-RED node for adding time to live (TTL) to messages and a second node for filtering messages which have timed out.
ttl set node will add a time of death _tod parameter to any message that passes through it. The _tod parameter is a timestamp that is equal to the time the message arrived at the node plus the amount of time set in the TTL property of the node.
ttl check node will compare the _tod parameter of a message with the current time. If the current time is past the _tod the message will be considered dead and not be propegated.
Version: 1.0.0
Updated 6 years, 10 months ago
2 in the last week
  • ttl-set
  • ttl-check
  • ttl
  • time to live
  • expire
  • message
