node-red-contrib-ttdu 0.2.0
Node-RED nodes for TTDU (Tools That Don't Upload): run document flows (PDF merge, redaction, payroll check, HWP to PDF) on this PC's offline runner or the TTDU hub API.
Node-RED nodes that run TTDU document flows (receipt photos → PDF, payroll check, personal-data redaction, HWP → PDF) on this PC's offline runner or the TTDU hub API.
Nodes: ttdu-config (connection: target, URL, API key) and ttdu run (flow A/B/C/HWP/HWP_TEXT/custom/from msg.flow).
Input: msg.files = [{name, data: Buffer}], uploads from an http in node (msg.req.files), or msg.payload Buffer + msg.filename (e.g. from file in). msg.vars (e.g. {client, date}) is merged over the node's vars.
Output: msg.payload = [{name, mime, size, sha256, data: Buffer}], msg.filename (first result), msg.inputFilename, msg.ttdu = {ok, count, steps, notes, target}. Errors go to catch nodes.
Install: Manage palette → Install → node-red-contrib-ttdu (or npm install node-red-contrib-ttdu in ~/.node-red). Requires Node-RED 3+ and Node.js 18+. Tested on Node-RED 4.1.2 and 5.0.9.
Examples (Import → Examples → node-red-contrib-ttdu): 01–04 HTTP endpoints for A/B/C/HWP, 05 folder watch → redact → output folder, 06 folder watch → HWP → PDF.
Where do my files go?
| Target | URL | Files |
This PC (local) |
http://127.0.0.1:8790 (the TTDU office runner, ttdu serve) |
Sent only to the runner on the same PC. The runner works with outbound network blocked, so files never leave the PC. |
Hub (hub) |
https://toolsthatdontupload.com |
Files are uploaded to the TTDU hub for the run (15 MB per request). Only server-capable tools run there (e.g. pdf.merge); the office flows A/B/C/HWP answer 422 unsupported on the hub - run them on This PC. |
If the automation tool runs in Docker Desktop, use http://host.docker.internal:8790 and start the runner with --allow-docker (the "local API, allow Docker" launcher in the office package). The runner still listens on 127.0.0.1 only and still needs the API key (local-api-key.txt).
Ready flows
| id | What it does | Input | Output |
A |
Receipt photos → one PDF, named {client}_{date}.pdf, ≤ 1 MB |
images | 1 PDF |
B |
Payroll check (4 insurances, income tax recalculated); period read from the file name YYYY-MM_…xlsx |
1 xlsx | {client}_<payroll check>_{date}.xlsx (Korean file name) |
C |
Redact resident registration numbers, phone numbers, account numbers | PDF / images | *-redacted-clean.* |
HWP / HWP_TEXT |
HWP/HWPX → PDF / text | hwp, hwpx | PDF / txt |
| custom | any ttdu.flow/v1 JSON exported from https://workflows.toolsthatdontupload.com |
API: POST /v1/flows/run (multipart flow, vars, files; header X-API-Key) → {ok, steps, notes, outputs:[{name, mime, size, sha256, base64}]}.
MIT © 2026 Park Jihoon (Tools That Don't Upload). This package contains only our code. It does not include or modify the host platform's code.
