node-red-contrib-trustpoint 1.0.5
Node-RED nodes for EST (Enrollment over Secure Transport) and certificate operations.
npm install node-red-contrib-trustpoint
A complete Node-RED nodeset for managing cryptographic keys and certificates using the Trustpoint EST protocol (Enrollment over Secure Transport).
Supports full EST device lifecycle management, including secure key generation, CSR creation, certificate enrollment, renewal, storage, and CA retrieval.
Designed for industrial and IoT provisioning workflows. Tested on Raspberry Pi 5 for ProductionLab Wall demo.
v1.0.5 – 2025-07-24
Improvements
  • ✨ Added support for mTLS: clientCert, clientKey, serverCert
  • 📁 Added example flows for each node (in /examples)
  • 🎨 Updated node color and improved label readability
  • 💡 Improved error handling and fallback for DER/PKCS#7 parsing
💡 Notes
  • Leaving filePath blank now stores files in a portable directory inside your Node-RED setup
  • No breaking changes – existing flows continue to work
  • 📌 Device key generation
    Generate RSA or Elliptic Curve (EC) private keys (configurable key size / curve).
  • 📌 CSR creation
    Create Certificate Signing Requests (CSR) from private keys, with configurable subject fields.
  • 📌 Full certificate enrollment
    Perform device enrollment with EST /simpleenroll endpoint, retrieve device certificates.
  • 📌 Certificate renewal
    Re-enroll devices using existing keys and certificates via /simplereenroll endpoint.
  • 📌 Certificate & key storage
    Save certificates and private keys to disk or Node-RED context, with extracted metadata (validity dates, subject CN, issuer CN).
  • 📌 CA certificate retrieval
    Retrieve and store CA certificate chain from EST /cacerts endpoint.
  • 📌 Node-RED integration
    Fully modular and reusable nodes, with flexible UI and payload structure.
  • 📌 Production-ready
    Tested on Raspberry Pi 5 (ProductionLab Wall demo), compatible with industrial IoT provisioning workflows.
Required Packages
To run the example flows successfully, make sure the following packages are installed in your Node-RED environment:
1. Custom Nodeset (this package)
  • node-red-contrib-trustpoint
    Your custom nodeset (this repository). Install it manually or via the Palette Manager.
2. Built-in Core Nodes (preinstalled in Node-RED)
  • inject
  • debug
  • function
These are included by default in Node-RED.
3. Optional (for UI flows)
If you're using Dashboard features (e.g., forms, buttons, charts), you will also need:
  • node-red-dashboard
Nodes included
Node Purpose
trustpoint-keygen Generate RSA or EC private keys (configurable key size / curve).
trustpoint-create-csr Create a CSR from a private key, with configurable subject fields (CN, O, OU, etc.).
trustpoint-build-enroll-payload Prepare the payload for EST enrollment, injecting CSR and credentials.
trustpoint-simpleenroll Perform certificate enrollment using the EST /simpleenroll endpoint.
trustpoint-simplereenroll (Optional) Perform certificate renewal using EST /simplereenroll endpoint.
trustpoint-prepare-keystore Prepare the keystore object and structure for re-use, including key, cert, and identifiers.
trustpoint-store-key Save private key to disk, using a sanitized device ID as filename.
trustpoint-store-certificate Save the issued certificate to disk and extract metadata (CNs, validity dates, key info, etc.).
trustpoint-cacerts Retrieve the CA certificate chain from the EST /cacerts endpoint.
trustpoint-store-ca Save the CA certificate to disk
Prerequisites
  • Node-RED >= 3.x
  • Node.js >= 18.x (tested with latest LTS)
  • EST server compatible with RFC 7030 (Enrollment over Secure Transport)
All required dependencies will be installed automatically, including:
node-forge request
⚠️ If using Node-RED via Docker, make sure to run the install command inside the container:
docker exec -it <your-container-name>
cd /data
Install via Node-RED Palette Manager
You can install this nodeset directly from the Node-RED editor:
  1. Open the Node-RED editor in your browser
  2. Click the menu (☰) → Manage palette → Install
  3. Search for: node-red-contrib-trustpoint
  4. Click Install
The Trustpoint nodes will appear under the "Trustpoint" category in the palette.
Manual installation (development mode)
You can also install it manually from source:
git clone https://github.com/ibrahimsambare/node-red-contrib-trustpoint.git
cd node-red-contrib-trustpoint
npm install
sudo npm link
npm link node-red-contrib-trustpoint
node-red-restart
Or restart Node-RED with this command:
node-red-stop
node-red-start
→ After restart, the Trustpoint nodes will be available in the Node-RED palette.
Example Flows
1️⃣ CA Certificate Retrieval Flow
Purpose:
Retrieve CA chain from EST /cacerts endpoint and store CA certificates as .pem or .p7b file.
inject → trustpoint-cacerts → trustpoint-store-certificate → debug
2️⃣ Full Device Enrollment Flow
Purpose:
Generate device key (RSA or EC). Create CSR with configurable subject. Perform certificate enrollment via EST /simpleenroll. Store device certificate on disk and extract metadata.
inject
  → trustpoint-keygen
  → trustpoint-prepare-keystore
  → trustpoint-store-key
  → trustpoint-create-csr
  → trustpoint-build-enroll-payload
  → trustpoint-simpleenroll
  → debug
3️⃣ Device Re-enrollment Flow
Purpose:
Use existing device private key and certificate. Generate a new CSR with same key. Perform certificate renewal via EST /simplereenroll. Store updated device certificate.
file-in (read existing key) + file-in (read existing cert)
inject
  → trustpoint-keygen
  → debug
Example Flow JSON files
👉 Full example flow definitions (.json) are available in the examples/ folder:
Compatibility
✅ Tested on:
  • Raspberry Pi 5 (64-bit Raspberry Pi OS, official OS image)
    → Physical Demo Setup for ProductionLab Wall
    → Node-RED installed and running as system service
  • macOS (development environment)
    → Node-RED running locally with node-red-contrib-trustpoint nodeset
  • Linux x64 (Ubuntu 22.04)
    → Node-RED running locally, manual installation of nodeset
✅ Node-RED version:
  • Node-RED 3.x → tested and validated
✅ Node.js version:
  • Node.js 18.x LTS → tested and validated
  • Node.js 20.x LTS → partial tests performed (no issues observed)
✅ EST server compatibility:
  • Trustpoint EST server (ProductionLab test instance)
  • /simpleenroll, /simplereenroll, /cacerts endpoints tested during Phase 1
Roadmap
✅ Phase 1 (completed):
  • Develop full node-red-contrib-trustpoint nodeset:
    • trustpoint-keygen
    • trustpoint-create-csr
    • trustpoint-simpleenroll
    • trustpoint-simplereenroll
    • trustpoint-store
    • trustpoint-cacerts
  • Build and test core flows:
    • CA retrieval flow → OK
    • Full device enrollment flow → OK
    • Device re-enrollment flow → Partially OK (HTTP 500 under investigation)
  • Write technical report → Completed
  • Prepare initial README → In progress
✅ Phase 2 (completed):
  • Prepare Raspberry Pi 5 environment (official OS, SSH, Node-RED installation)
  • Deploy node-red-contrib-trustpoint nodeset on Raspberry Pi 5
  • Validate flows on ProductionLab Wall
  • Demo physical setup to Trustpoint team
✅ Phase 3 (completed):
  • Add and test full mTLS support (client cert + client key for all endpoints)
  • Investigate and resolve /simplereenroll HTTP 500 issue
  • Add reusable Node-RED configuration node (trustpoint-config) if needed
  • Implement automated test flows (unit + integration tests)
  • Add CI/CD pipeline (GitHub Actions)
  • Publish nodeset to npm and Node-RED Flow Library
  • Provide additional advanced example flows (auto-renewal, MQTT integration, etc.)
✅ Phase 4 (completed)
  • Implement advanced enrollment strategies:
  • Certificate renewal via /simplereenroll with valid client certificate
  • Enrollment retry mechanisms and error handling
  • Add Node-RED Dashboard templates for user-friendly device provisioning
  • Develop full demo for MQTT over mTLS using enrolled certificates
  • Publish documentation site (e.g., GitHub Pages or MkDocs)
  • Optimize node UI and UX (tooltips, help descriptions, validation)
  • Engage with the community via Node-RED Flow Library feedback and GitHub Issues
MIT License
Copyright (c) 2025 Ibrahim Almountaka Sambare
Author
Developer of node-red-contrib-trustpoint
Phase 1 — Trustpoint Project (ProductionLab Wall demo)
2025
GitHub: https://github.com/ton-profil-github
Email: [email protected]
Version: 1.0.5
Updated 1 year, 4 months ago
43 in the last week
  • trustpoint-keygen
  • trustpoint-store-certificate
  • trustpoint-store-key
  • trustpoint-build-enroll-payload
  • trustpoint-prepare-keystore
  • trustpoint-store-ca
  • est
  • trustpoint
  • tls
  • certificate
  • x509
