node-red-contrib-truma-inetx 1.1.0
Node.js BLE Lib, Cli and nodered device for Truma iNet X.
TypeScript BLE library, CLI, and Node-RED nodes for reading and writing Truma iNet X settings.
The implementation speaks the Truma iNet X application protocol, decodes CBOR
payloads with cbor-x, and prints parsed settings as JSON. Bluetooth access is
backend based: auto tries BlueZ on Linux and falls back to noble elsewhere,
while bluez and noble can be selected explicitly.
The connection is intentionally released after each read, discovery, or write operation. This leaves the panel available for the Truma phone app between Node-RED operations, instead of occupying its Bluetooth connection continuously. Allow time between polling requests so the phone app can connect.
Related projects
Python / Home Assistant alternative
daaaaan/truma-inetx-ble is an alternative Python implementation with Home Assistant integration, MQTT, and a standalone service for Victron Cerbo GX / Venus OS. It may be a useful option if you prefer a Home Assistant / Python solution to a Node-RED integration.
The two projects were developed independently. We discovered that project by chance after developing this implementation; its development started earlier. Sharing protocol findings and interoperability experiences could help both projects support more Truma setups.
Victron dashboards and GX Touch integration
Mathieu0994/Victron-x-Truma-Integration- uses this package for BLE communication and adds a Node-RED Dashboard 2 UI accessible through VRM, a D-Bus bridge, and a custom GX Touch page for controlling a Truma D6E from a Victron GX device. It is a complementary project for users looking for a ready-made Venus OS interface built on this library. See its README for tested hardware, firmware versions, and deployment limitations.
Install dependencies:
npm install
For Linux / Venus OS using BlueZ only, npm install --omit=optional skips the
native noble backend and its build dependencies. The BlueZ path needs Node.js,
the running system Bluetooth service, and D-Bus access; no Python service is
needed. Noble remains available as an optional backend for other platforms.
Use Node 20 or 22 LTS for live BLE access. Newer Node releases can work for tests and builds, but the native noble macOS backend has been less reliable for Bluetooth connections outside LTS.
Get settings:
npm run get
Use --debug for BLE/protocol diagnostics on stderr:
npm run get -- --debug
Select a Bluetooth backend when needed:
npm run discover -- --bluetooth bluez
npm run get -- --bluetooth noble
Pair with the iNet X display while the display is in Bluetooth pairing mode:
npm run pair
On Venus OS / Linux, BlueZ pairing is preferred so bluetoothd owns the
Device1 object and persists bond keys:
npm run pair -- --bluetooth bluez --debug
Pairing-specific BlueZ controller settings are only applied by pair, not by
normal discover, get, or set.
Headless Venus OS / Victron
Open the truma-inetx-device configuration and select the adapter. Put your panel
in Bluetooth pairing mode, click Search, then select its name. Selecting a
device starts pairing automatically; opening the editor or searching does not.
Confirm on the panel if requested. Pairing uses the current
editor selection, so it can run before deployment. Deploy afterwards and use
Reread to refresh topic names and the device list. Use a Get node to read
parameter values; it learns missing topic groups within that same connection.
Deleting a Node-RED device configuration does not delete the Linux Bluetooth bond. To reset it, select an explicit adapter and click Forget pairing…. Choose a device from the list, click Forget selected device, and confirm. Only then are that host bond and cached records removed, affecting all flows using the same device on that adapter. It does not remove your phone's pairing. You may also need to remove this host on the Truma panel. Search again, select the panel's current entry to pair again. Forgetting a different device leaves the current selection unchanged. Update and Deploy to save a cleared selection.
The search list shows device names and can include cached devices. Linux's stored bond can remain after deleting pairing on the panel. The forget list also shows addresses so you can distinguish records with the same name. A stale public identity address and a new unpaired random address may therefore appear with the same name; the name alone does not prove they are the same physical device.
The Connection dropdown defaults to Close after every request, so the phone can connect between requests. Alternatively, choose Keep open until idle timeout (experimental) and set the number of minutes (default 1). Requests reuse the connection and reset the idle timer. Failed requests, redeployment, and editor Bluetooth operations or requests for another device close it immediately. The phone app can connect after the connection closes. The timeout counts from request completion. Some panels or Bluetooth adapters may drop a retained connection before the idle timeout. Use close-after-request mode if repeated reads become unreliable. Pair first: reading an unpaired BlueZ device reports an error instead of opening a connection that waits for pairing.
Editor pairing requires BlueZ on Linux and permission for the Node-RED process to use the system Bluetooth D-Bus API. It does not change controller-wide settings. Panels requiring the older controller preparation can still use the CLI pairing path. Pairing and adapter changes need validation on your actual panel/firmware; automated tests use simulated devices.
The Adapter dropdown lists detected hardware as hci0 (MAC address) and stores
the MAC address, which stays stable across hci renumbering. Automatic lets the
backend choose. A saved adapter that is absent remains visible as unavailable.
The CLI also accepts hci0 / hci1 or a BlueZ object path. The same adapter is used for
discovery, pairing, reading and writing. An explicit missing adapter fails
instead of silently choosing another. With an adapter selected, auto uses
BlueZ; explicit noble requires leaving the adapter blank.
CLI equivalents:
npm run get -- --adapter hci1 --device-address AA:BB:CC:DD:EE:FF
npm run pair -- --bluetooth bluez --adapter hci1 --device-address AA:BB:CC:DD:EE:FF --passkey 001234
A CLI passkey may be saved by shell history. Panels requiring a code can use the
CLI's --passkey option; the editor has no code field.
Local time
SystemTime.Time remains Unix time in UTC. SystemTime.Lot now carries the local
UTC offset in minutes, including daylight saving time (for example, Germany
60/120, Auckland 720/780). It defaults to the Node-RED/CLI host timezone.
In the device editor, leave Timezone blank (or click Automatic (host)) to use
the computer running Node-RED. The editor offers timezone suggestions as you type. Use browser timezone copies the
timezone of the computer or phone opening the editor into the configuration;
it stays selected until you change it. This does not change the host OS timezone.
Override it with an IANA timezone in the device configuration, via CLI
--time-zone Europe/Berlin, or library protocol: { timeZone: 'Europe/Berlin' }.
This is useful when the GX host runs in UTC; travelling users should update the
configured timezone when necessary.
Initial Build of Settings Tree
Build a reusable settings tree:
npm run discover > truma-tree.json
The tree includes topic group ids, so later reads and writes can target only the needed device groups:
npm run get -- Switches
Tree topics are grouped by topic name, then parameter name:
"topics": {
"Switches": {
"group": "0x0405",
"parameters": {
"ExternalLights": {
"type": 104,
"available": 1,
"value": 1
Set a parameter:
npm run set -- Switches ExternalLights 1 --tree truma-tree.json
The write path initializes the Truma protocol to learn the assigned client
address, then sends a single parameter write. Switch captures use numeric 1
and 0 values. You can also pass --group 0405 explicitly instead of --tree.
A successful set() result includes write.status: "confirmed" only after the
target group reports the requested topic, parameter and value. A timeout raises
WriteUnconfirmedError (code: "TRUMA_WRITE_UNCONFIRMED"): the write may have
succeeded, so read it back before retrying. Writes are never automatically
repeated, including when callers supply the legacy readRetries option. In
Node-RED, unconfirmed writes use a yellow status and go to the Catch node without
emitting a successful result.
The set node validates values against cached parameter metadata (availability,
numeric bounds and available enum choices). CLI --tree provides the same
checks, and library callers can pass metadata. Without metadata, only basic
value checks apply; no ranges or permission-bit meanings are guessed. Values
remain in protocol units, such as tenths of a degree Celsius. Read the affected
topic again when the panel configuration changes.
Known working controls and topic mappings are documented in
docs/control-examples.md. In particular, room
heating is split across RoomClimate and AirHeating: use RoomClimate for
off/heating/ventilation mode, but use AirHeating.TgtTemp for the room heating
target temperature and AirHeating.Mode for the heater fan/profile.
The CLI writes a single JSON document to stdout. It does not write files.
Generated build output lives in dist/ and is ignored by git.
Library
Build the TypeScript library:
npm run build
Run tests:
npm test
Primary exports:
pair()connects and triggers the operating-system pairing flow.get()connects, reads, decodes, disconnects, and returns JSON.discover()builds a reusable settings tree with topic group ids.set()initializes the protocol, writes one parameter, decodes confirmation responses, disconnects, and returns JSON.TrumaProtocolhandles the app-level control/data frame exchange.buildTrumaFrame(),buildParameterWriteFrame(),decodeTrumaFrame(), anddecodeFirstCbor()handle Truma frame/CBOR helpers.collectSettings()andparseSettingsJson()normalize topic/parameter responses.
Node-RED
Installing this package into Node-RED registers three nodes:
truma-inetx-device: config node that discovers topic names and the device list on deploy/start, without querying every device group's parameters.truma-inetx-get: gets all settings or multiple selected topics. Incomingmsg.payloadmay override topics with a string, array, or{ "topics": [...] }.truma-inetx-set: sets one topic/parameter/value. Incomingmsg.payloadmay override with{ "topic", "parameter", "value", "group" }. If the topic's group is unknown, it first reads that topic to learn its group and metadata.
The operational nodes and editor discovery/pairing actions serialize BLE access across all Truma device nodes in this Node-RED process. Each operation disconnects when finished. This does not coordinate with separate CLI processes; avoid running them during Node-RED polling.
For room and boiler sensors on Venus OS, import examples/victron-temperatures.json. It uses the official Victron virtual-device nodes, converts raw temperature units once, and disconnects missing or stale sensors. See the setup guide.
