node-red-contrib-trotec 3.0.0-beta.8
Trotec laser specific nodes
npm install node-red-contrib-trotec
Trotec Node-RED Custom Nodes
npm version Node-RED Library
Custom npm package for Node-RED to extend the available palette with Trotec-specific nodes for automation purposes.
These nodes are designed to boost productivity and simplify automation of customer workflows. By integrating Trotec machines with Node-RED, users can easily create, manage, and optimize automation processes, reducing manual effort and enabling rapid deployment of tailored solutions.
  • Trotec-specific automation nodes for Node-RED
  • Easy integration into Node-RED flows
  • Designed for Trotec automation
  • Supports rapid prototyping and deployment
To install Trotec nodes in Node-RED, always use the Palette Manager:
  1. Open Node-RED.
  2. Click the menu button (top right) and select Manage palette.
  3. Search for node-red-contrib-trotec and click Install.
This is the recommended and supported way to install Trotec nodes in Node-RED.
Getting Started
  1. Ensure Node-RED is installed and running.
  2. Install this package using npm or the Palette Manager.
  3. Restart Node-RED if required.
  4. Find the "Trotec" nodes in the Node-RED editor sidebar.
  5. Configure connection to your Trotec machine:
    • Add any trotec node to your flow.
    • select add new configuration.
    • Enter the machine's connection details (IP address, credentials, etc.) in the configuration node.
    • Save and deploy your flow.
conf 2
  1. Open Node-RED.
  2. Add nodes from the "Trotec" category to your flow.
  3. Configure each node according to your automation requirements.
Example
Included example flows are available directly in Node-RED:
  • Go to the Node-RED editor.
  • Click the menu button (top right) and select Import > Examples.
  • Choose the "Trotec" examples to explore ready-made flows and usage patterns.
Documentation
See the Node-RED documentation for general usage.
Refer to the package documentation for node-specific configuration and examples.
Node-RED Library
Find this package in the Node-RED Library.
Contributing
For contributions, issues, or support requests: Please raise a support ticket with technical services via our webform - https://www.troteclaser.com/en/contact/technical-support
MIT
Author
Trotec Laser GmbH
Version: 3.0.0-beta.8
Updated 2 months, 1 week ago
Rating: 5.0 3
13 in the last week
  • trotec configuration
  • get device status
  • get designs
  • get workbenches
  • get import profiles
  • get data source
  • get job status
  • get queue elements
  • get queue element detail
  • delete all items
  • delete design
  • delete queue element
  • delete workbench
  • upload from design
  • upload from many designs
  • upload from files
  • update variable
  • enqueue workbench
  • replace datasource
  • event listener
  • multichannel event listener
  • get table camera
  • trotec
  • ruby
