node-red-contrib-triggerable-browser-utils 0.1.0
A fork of node-red-contrib-browser-utils with triggerable nodes for browser interaction (camera, microphone, file upload) via flows. Based on original work by IBM Corp. and contributors.
npm install node-red-contrib-triggerable-browser-utils
日本語版はこちら (Japanese version)
Node-RED nodes for browser functionality such as file upload, camera, and microphone
with support for triggering from Inject nodes and function nodes, not just the node-side button.
About this project
This repository is a fork of node-red-contrib-browser-utils.
In addition to the original "button-only trigger" design, this version allows camera, microphone, and file upload nodes to be triggered from Inject nodes, Function nodes, or any upstream node in your flow.
Or using Node-RED's Palette Manager:
  1. Go to the Node-RED menu
  2. Select "Manage palette"
  3. Click the "Install" tab
  4. Search for "triggerable-browser-utils"
  5. Click install
Triggerable Camera (trig camera)
The camera node allows you to capture images from a connected camera or webcam.
Features:
  • Trigger image capture from inject nodes or the node's button
  • Select specific camera device when multiple cameras are available
  • Choose output format: Buffer or Base64 string
  • Set interval for continuous captures
  • Supports Chrome and Firefox browsers
Properties:
  • Name: Customize the node name
  • Interval (ms): Set delay between captures for continuous mode (default: 2000ms)
  • Camera: Select which camera device to use
  • Output Format: Choose between Buffer (default) or Base64 string
Outputs:
  • msg.payload: The captured image in PNG format (as Buffer or Base64 string)
  • msg.content_type: 'image/png'
  • msg.format: 'buffer' or 'base64'
  • msg.timestamp: Capture timestamp
Control via message:
// Basic trigger
msg.payload = {}; // Simple trigger
// With specific command
msg.payload = { command: "capture" }; // Take a single picture
msg.payload = { command: "start" }; // Start camera
msg.payload = { command: "stop" }; // Stop camera
msg.payload = { command: "loop", interval: 5000 }; // Continuous capture every 5 seconds
Triggerable Microphone (trig microphone)
The microphone node enables audio recording from a connected microphone.
Features:
  • Start/stop recording via inject nodes or the node's button
  • Toggle behavior: first trigger starts recording, second trigger stops
  • Select specific microphone device when multiple are available
  • Supports Chrome and Firefox browsers (HTTPS required)
Properties:
  • Microphone: Select which microphone device to use
Outputs:
  • msg.payload: The recorded audio in WAV format (Buffer)
  • msg.content_type: 'audio/wav'
  • msg.timestamp: Recording timestamp
// Toggle recording (start/stop)
msg.payload = {}; // Simple trigger toggles recording state
msg.payload = { command: "start" }; // Start recording
msg.payload = { command: "stop" }; // Stop recording and output WAV
Triggerable File Inject (trig file inject)
The file inject node allows uploading files from the browser to your flow.
Features:
  • Two operation modes:
    1. Pre-configured file: Upload and store a file in the node's configuration
    2. On-demand selection: Trigger a file selection dialog when activated
  • Trigger file sending via inject nodes or the node's button
Properties:
  • File: Select and upload a file to store in the node (when in pre-configured mode)
Outputs:
  • msg.payload: The file data (Buffer)
  • msg.filename: Original filename
  • msg.mimetype: MIME type of the file
// Simple trigger to send the pre-configured file
msg.payload = {}; // Sends the configured file
// Using stored file allows automated workflows without manual file selection
Browser Compatibility and Requirements
  • HTTPS Required: Camera and microphone access require a secure context (HTTPS)
  • Supported Browsers: Chrome, Firefox, and other modern browsers
  • Permissions: Users must grant permission to access camera and microphone
  • Dashboard Usage: Works great with Node-RED dashboard, allowing user media interaction
Technical Details
Camera Node
  • Uses navigator.mediaDevices.getUserMedia() for camera access
  • Captures images by drawing video frames to a canvas element
  • Converts to PNG format using canvas.toBlob()
  • Images are sent back to Node-RED via HTTP POST
Microphone Node
  • Uses Web Audio API for recording
  • Records audio in WAV format
  • Maximum recording time is limited by browser memory
File Inject Node
  • Uses standard HTML5 file input for file selection
  • Pre-configured files are stored in Base64 format
Tips for Use
  1. Use with Dashboard: These nodes work well in dashboard environments for interactive applications
  2. Error Handling: Always add error handling since browser permissions might be denied
  3. Multiple Instances: You can have multiple instances of each node targeting different devices
  4. Security: Remember that all browser interactions require user permission
  5. Chain Processing: Connect to image/audio processing nodes for advanced applications
Main differences from the original
  • Triggering from flows: All nodes can now be triggered by Inject, Function, or other nodes, not just the node-side button
  • Device selection: Added ability to select specific camera and microphone devices
  • Output formats: Camera node supports both Buffer and Base64 output
  • Pre-configured files: File inject node can store files for automated workflows
Contributing & License
Pull requests and bug reports are welcome.
This project is licensed under the Apache 2.0 license.
This repository is based on work by IBM Corp. in node-red-contrib-browser-utils,
with modifications and enhancements by Nobisuke Sugawara.
Version: 0.1.0
Updated 1 year, 7 months ago
139 in the last week
  • triggerable-camera
  • triggerable-microphone
  • triggerable-fileinject
  • microphone
  • camera
  • upload
  • Nobisuke Sugawara(@n0bisuke)
