node-red-contrib-trello-functions 2.13.1
A set of function nodes for trello api
This is my first node project, the idea is to have very easy and simple to use node functions that capture meaningful Trello events.
As this is my first project I am a little unsure where to take this, so I am very open to any suggestions or help and it will be greatly appreciated.
Current nodes
New Trello card
Outputs a Trello card for every new card added as msg.payload.
Output is time bounded between the previous and current activation.
Safe/ Block list to exclude any actions performed by the certain users.
Assigned to Trello card
Outputs a Trello card for every card the Trello user is assigned to as msg.payload.
Get card moved lists
Outputs a Trello card that has moved Trello list as msg.payload.
Get card moved to list
Outputs a Trello card that has moved to a specific Trello list as msg.payload.
Get list
Outputs all cards in a Trello list.
I plan to add query params in a future update.
Create new Trello card
Able to create an array of Trello cards based on input, with optional default values available.
Add Label to Trello Card
Adds a predefined label to a Trello card.
Move card to list
Moves a Trello card to a specified list.
If card in list
Simple helper by means of a drop down list select, with 2 outputs 1 for True the other for False.
Meaningful card position
Simple helper that calculates an incremental positional value starting at 1 for the top card, also has a separate output if it is the top or bottom card.
Update card
Updates the card in Trello after modifying it in node-red.
Current plans to implement
- Adding a whitelist/blacklist of users to allow filtering by users
- Currently in active development taking suggestions on other nodes feel free to create an issue on github or email me at [email protected].
