node-red-contrib-trashschedule 1.3.7
NodeRED Node to manage trash schedule events
npm install node-red-contrib-trashschedule
banner
Node Red Trash Schedule
NPM NPM_downloads issues Node.js CI
NPM
The node-red-contrib-trashschedule Node is the ultimative Node to manage your Trashschedule events.
Please make sure that you've picked the right timezone into your system settings!
Node Description
Settings
Add your trashschedule events into the list.
list_example
field required input
1 event day (1-31)
2 event month (1-12)
3 event year (yyyy example: 2021)
4 event name
Select the hour until the trashschedule event will be displayed.
skip_example
The last field "Name" gives the possibility to change the name which will be displayed for this node into your flow.
Input
You can use the input to trigger events manually. The keywords are listed below.
msg.payload output
checkTrashschedule return next trashschedule event
checkNextThree return next three trashschedule event
all return all trashschedule event
Output
Every hour the node returns the next trashschedule event (output 1) and next three trashschedule events (output 2). It returns the trashschedule events as an object. If there isn't a trashschedule event available you will receive the payload "Trashschedule events outdated". The next three trashschedule events are packed into an array.
key value
name event's name
day event's day
month event's month
year event's year
Example Flow
flow_example
You can import this example into your Node Red flow.
[{"id":"fec0be7818a3b438","type":"trashschedule","z":"7035994dcde5f3c9","name":"Trash Schedule","trashschedule":[{"name":"Restmüll","day":"3","month":"9","year":"2022"},{"name":"Papiertonne","day":"4","month":"3","year":"2022"},{"name":"Biotonne","day":"5","month":"8","year":"2023"},{"name":"Gelbe Tonne","day":"2","month":"2","year":"2022"}],"skipHour":12,"x":450,"y":260,"wires":[["b8e1b4ecca4d94b4"],["2514c3ce60ebc8ec"],["867c0090bf72aa2a"]]},{"id":"9ed74172ad019d57","type":"inject","z":"7035994dcde5f3c9","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"checkTrashschedule","payloadType":"str","x":230,"y":220,"wires":[["fec0be7818a3b438"]]},{"id":"2514c3ce60ebc8ec","type":"debug","z":"7035994dcde5f3c9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":260,"wires":[]},{"id":"867c0090bf72aa2a","type":"debug","z":"7035994dcde5f3c9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":300,"wires":[]},{"id":"b8e1b4ecca4d94b4","type":"debug","z":"7035994dcde5f3c9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":220,"wires":[]},{"id":"8b9bbfffbf7eec36","type":"inject","z":"7035994dcde5f3c9","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"checkNextThree","payloadType":"str","x":240,"y":260,"wires":[["fec0be7818a3b438"]]},{"id":"fa3b06b5a4cdbf50","type":"inject","z":"7035994dcde5f3c9","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"all","payloadType":"str","x":270,"y":300,"wires":[["fec0be7818a3b438"]]}]
Version: 1.3.7
Updated 1 year, 1 month ago
38 in the last week
  • trashschedule
  • trash
  • muell
  • smart home
  • schedule
  • trashschedule
  • muellabfuhr
  • calendar
