node-red-contrib-traffic-flash 1.0.0
A lightweight visual indicator node for Node-RED that flashes when data passes through.
npm install node-red-contrib-traffic-flash
A lightweight visual indicator node for Node-RED that blinks/flashes whenever data passes through it.
Drop it anywhere along a wire to verify message flow, check throughput, or debug timing without cluttering the debug sidebar or spamming logs.
  • Zero-Mutation Pass-Through: Forwards msg instantly and untouched.
  • Visual Pulse: Lights up the node status indicator on every message.
  • Configurable Pulse Duration: Set how long the indicator stays active (e.g. 100ms, 500ms, 1000ms).
  • Status Text Options:
    • None: Just the blinking light.
    • Message Count: Displays cumulative messages received (e.g., 1 msg, 42 msgs).
    • Timestamp: Displays the time of the latest message (HH:MM:SS).
    • Payload Preview: Compact inline preview of msg.payload.
  • Idle Modes:
    • Clear: Status indicator completely vanishes when idle.
    • Grey Ring: Dim grey outline indicating the line is armed and awaiting traffic.
    • Keep Last: Dim grey outline retaining the last counter or payload value.
  • Reset Capability: Send msg.reset = true or msg.topic = 'reset' to zero out the counter and restore idle status.
Via Node-RED Editor (Recommended)
  1. Open your Node-RED editor.
  2. Go to the top right menu ☰ → Manage palette.
  3. Select the Install tab.
  4. Search for node-red-contrib-traffic-flash and click install.
Via Terminal / Command Line
Inside your Node-RED user directory (typically ~/.node-red):
Then restart Node-RED.
Property Default Description
Flash Color Green Color while active (green, yellow, blue, red, grey).
Flash Shape Dot Indicator shape (dot solid or ring outline).
Duration (ms) 500 How long the active flash persists after receiving a message.
Status Text None Text displayed beside the indicator (none, count, timestamp, payload).
Idle State Clear Appearance when traffic pauses (clear, grey ring, last ring).
Example Flow
Copy the following JSON and import it into Node-RED (☰ → Import → Clipboard):
    "id": "inject_traffic",
    "type": "inject",
    "z": "tab1",
    "name": "Simulate Sensor Tick",
    "props": [{"p": "payload"}],
    "repeat": "1",
    "crontab": "",
    "once": true,
    "onceDelay": 0.1,
    "topic": "",
    "payload": "heartbeat",
    "payloadType": "str",
    "x": 160,
    "y": 120,
    "wires": [["traffic_flash_node"]]
    "id": "traffic_flash_node",
    "type": "traffic-flash",
    "z": "tab1",
    "name": "Traffic Tap",
    "flashDuration": 300,
    "flashColor": "green",
    "flashShape": "dot",
    "idleState": "grey",
    "displayText": "count",
    "x": 380,
    "y": 120,
    "wires": [["debug_out"]]
    "id": "debug_out",
    "type": "debug",
    "z": "tab1",
    "name": "Output",
    "active": false,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "payload",
    "targetType": "msg",
    "statusVal": "",
    "statusType": "auto",
    "x": 560,
    "y": 120,
MIT © Greg Clauson
Version: 1.0.0
Updated 3 weeks, 1 day ago
  • traffic-flash
  • traffic
  • indicator
  • flash
  • activity
  • debug
  • monitor
  • status
