node-red-contrib-tractive 1.0.0
Node-RED palette for the Tractive GPS tracker API — monitor battery, location, and control LED/buzzer.
npm install node-red-contrib-tractive
A Node-RED palette for the Tractive GPS tracker API. Monitor your pet's battery level, location, and history — and control LED and buzzer — directly from your flows.
Install via the Node-RED Palette Manager (search for node-red-contrib-tractive), or from the command line in your Node-RED data directory:
tractive-config
A configuration node that stores your Tractive account credentials. One config node per account — shared across all tractive-tracker nodes in your flow.
Field Description
Email Your Tractive account email
Password Your Tractive account password
Authentication is performed automatically when the first operation runs.
tractive-tracker
Calls the Tractive API for a specific tracker. Configure the Tracker ID once (find it in the Tractive app under Settings → Device → Device ID) and select the operation.
Operations
Operation Description
Get hardware Battery level and charging state
Get location Latest GPS fix with coordinates and address
Get history Location history (requires msg.from and msg.to)
Live tracking ON / OFF Enable or disable 2.5-second position updates
LED ON / OFF Trigger the tracker's LED light
Buzzer ON / OFF Trigger the tracker's buzzer
Get pets List all pets on the account
Get all trackers List all trackers on the account
Runtime overrides
Property Description
msg.trackerID Overrides the Tracker ID set in the node
msg.operation Overrides the operation set in the node
msg.from Start timestamp in ms (Get history only)
msg.to End timestamp in ms (Get history only)
Output
msg.payload contains the raw API response object.
Example — battery monitor
[inject every 5 min] → [tractive-tracker: getTrackerHardware] → [msg.payload.battery_level] → [display]
JavaScript library
The package also works as a standalone ESM library:
import tractive from 'node-red-contrib-tractive';
await tractive.connect('[email protected]', 'password');
const hw = await tractive.getTrackerHardware('YOUR_TRACKER_ID');
console.log(hw.battery_level); // e.g. 85
const location = await tractive.getTrackerLocation('YOUR_TRACKER_ID');
console.log(location.latlong); // e.g. [-33.86, 151.20]
All functions
// Account
getAccountInfo()
getAccountSubscriptions()
getAccountSubscription(subscriptionID)
getAccountShares()
// Pet
getPets()
getPet(petID)
// Tracker
getAllTrackers()
getTracker(trackerID)
getTrackerLocation(trackerID)
getTrackerHardware(trackerID)       // includes battery_level, charging_state
getTrackerHistory(trackerID, from, to)  // from/to are timestamps in ms
// Commands
liveOn(trackerID)
liveOff(trackerID)
LEDOn(trackerID)
LEDOff(trackerID)
buzzerOn(trackerID)
buzzerOff(trackerID)
Notes
  • Rate-limited requests (HTTP 4006) are automatically retried up to 3 times with a 2-second delay.
  • This package is not affiliated with or maintained by Tractive. Tractive is a registered trademark of Tractive GmbH.
Version: 1.0.0
Updated 5 months, 2 weeks ago
  • tractive
  • GPS
  • tracker
  • pet
  • tracking
