node-red-contrib-tplink-tapo-connect-api 0.5.9
This unofficial node-RED node allows connection to TP-Link Tapo devices. This project has been enhanced with AI support to enable new features. Starting with v0.50, we have added support for the KLAP protocol. To prioritize the operation of this node, we
npm install node-red-contrib-tplink-tapo-connect-api
This unofficial node-RED node allows connection to TP-Link Tapo devices. This project has been enhanced with AI support to enable new features. Starting with v0.50, we have added support for the KLAP protocol. To prioritize the operation of this node, we have simplified its functionality.
node
Supported Devices
Device Model Type Energy Monitoring Status
P100 Smart Plug ❌ ✅ Supported
P105 Smart Plug ❌ ✅ Supported
P110 Smart Plug with Energy Monitoring ✅ ✅ Supported
P115 Smart Plug with Energy Monitoring ✅ ✅ Supported
TP15 Smart Plug ❌ 🧪 Experimental Support
L510 Smart Bulb (Dimmable) ❌ ✅ Supported
L520 Smart Bulb (Dimmable) ❌ ✅ Supported
L530 Smart Bulb (Color) ❌ ✅ Supported
L535 Smart Bulb (Color) ❌ ✅ Supported
Supported Features by Device
Feature P100/P105 P110/P115 TP15 L510/L520 L530/L535
Device Info ✅ ✅ 🧪 ✅ ✅
Power On/Off ✅ ✅ 🧪 ✅ ✅
Device Usage ✅ ✅ 🧪 ✅ ✅
Current Power ❌ ✅ ❌ ❌ ❌
Energy Data ❌ ✅ ❌ ❌ ❌
Energy Usage ❌ ✅ ❌ ❌ ❌
Brightness Control ❌ ❌ ❌ ✅ ✅
Color Control ❌ ❌ ❌ ❌ ✅
Color Temperature ❌ ❌ ❌ ❌ ✅
nodes
  • toggle
    node-command
    This node module provides the ability to toggle (on / off) the power of tapo smart plugs.
    Note: When executed immediately, the device status may not be synchronized, which can cause toggle operations to fail. Please wait 10-30 seconds before executing the toggle operation.
  • turn-on
    node-command
    This node module provides the ability to power on tapo smart plugs.
  • turn-off
    node-command
    This node module provides the ability to power off tapo smart plugs.
  • brightness
    node-brightness
    This node module provides the ability to set the brightness of tapo smart bulbs.
  • colour
    node-command
    This node module provides the ability to set the color of tapo smart bulbs.
  • command
    node-command
    This node module provides several features by input "msg.payload.command".
    1. power
      tapo device power on/off
      msg.payload.option
      0: tapo device power off
      1: tapo device power on
    2. toggle
      tapo device power on/off(toggle)
    3. status
      get tapo device info
  • status
    node-command
    This node module provides the ability to get the device infomation of tapo smart plugs.
    Models that can monitor energy acquire energy information.
    Get the device information from "output: msg.payload.tapoDeviceInfo, msg.payload?.tapoEnergyUsage(P110 only)".
Pre-requisites
The node-red-contrib-tplink-tapo-connect-api requires Node-RED to be installed.
Quick Start
To pull from docker hub:
docker pull sanlike0911/node-red-tplink-tapo-connect-api:latest
  • Properties
    config
    • Name
      Set the node name displayed in the flow.
    • Email
      Set the email address registered with Tp Link.
    • Password
      Set the password registered with Tp Link.
    • Tapo IP Address
      Set the IP address of the Tapo device on your local network.
Inputs
msg.payload
type commandTypes = "" | "power" | "toggle" | "status";
type payload {
    email: string;
    password: string;
    deviceIp: string;
    command: commandTypes;          /* "node-command" only */
    option: {                       /* "node-command" only */
        power?: number;
    colour: string;                 /* "node-colour" only */
    brightness: number;             /* "node-brightness" only */
[example1]
msg = {
  "email": "[email protected]",
  "password": "password",
  "deviceIp": "192.168.0.xxx",
  "command": "power",
  "option": {
    "power": 0
[example2]
msg = {
  "command": "toggle"
Outputs
The processing result is passed by msg.payload. It consists of an object that contains the following properties:
type tapoConnectResults = {
    result: boolean; /* true: success, false: failure */
    tapoDeviceInfo?: tapoDeviceInfo; /* smart plug device infomation */
    errorInf?: Error;
[smart plug device infomation]
You can tell if the device is on or off by getting "device_on".
true: smart plug power on
false: smart plug power off
  "result": true,
  "tapoDeviceInfo": {
    "device_id": "*************",
    "fw_ver": "1.2.3 Build 240617 Rel.153525",
    "hw_ver": "1.0",
    "type": "SMART.TAPOPLUG",
    "model": "P110M",
    "mac": "XX-XX-XX-XX-XX-XX",
    "hw_id": "*************",
    "fw_id": "*************",
    "oem_id": "*************",
    "ip": "192.168.0.100",
    "time_diff": 540,
    "ssid": "U0FOTElLRV9Jb1Q=",
    "rssi": -41,
    "signal_level": 3,
    "auto_off_status": "off",
    "auto_off_remain_time": 0,
    "longitude": 1370345,
    "latitude": 352543,
    "lang": "ja_JP",
    "avatar": "plug",
    "region": "Asia/Tokyo",
    "specs": "JP",
    "nickname": "44Ko44Ki44Kz44Oz",
    "has_set_location_info": true,
    "device_on": true,
    "on_time": 1965,
    "default_states": {
      "type": "last_states",
      "state": {}
    "overheat_status": "normal",
    "power_protection_status": "normal",
    "overcurrent_status": "normal",
    "charging_status": "normal"
  "tapoEnergyUsage": {
    "today_runtime": 515,
    "month_runtime": 681,
    "today_energy": 215,
    "month_energy": 1224,
    "local_time": "2025-07-28 23:38:34",
    "electricity_charge": [
      0,
      0,
      0
    "current_power": 405681
npm-scripts
There are some npm-scripts to help developments.
  • npm install - Install the testing environment in your project.
  • npm run build - Make ./data/my-node directory from the src directory and Install the my-node in Node-RED.
  • npm run start - Start Node-RED. "http://localhost:1880"
file list
[root]
│  package.json
│  README.md
│  tsconfig.json
├─data -> `Node-Red work files`
│  ├─my-node -> `project files` The resource files and built files should be placed here.
│  │  │  package.json
│  │  └─nodes -> The resource files and built files should be placed here.
│  └─node_modules
├─dist -> `The project built files`
├─examples -> `node-RED flow files`
├─figs
└─src
    └─nodes -> project files
        ├─icons
        ├─lib
        ├─locales
        │  ├─en-US
        │  └─ja
        └─test
Version: 0.5.9
Updated 1 year, 1 month ago
License: Apache
Rating: 4.1 17
36 in the last week
  • tplink
  • IoT
  • Smart Plug
  • Energy Monitoring
  • Smart Bulb
  • P100
  • P105
  • P110
  • P115
  • TP15(Experimental)
  • L510
  • L520
  • L530
  • L535(Experimental)
