node-red-contrib-tplink-smarthome 0.1.1
A collection of node-red nodes for tp-link smart home devices
npm install node-red-contrib-tplink-smarthome
NPM Version
TP-Link Smart Home Node-Red Nodes
This is a collection of Node-Red nodes that allow you control smart plugs and bulbs from the TP-Link smart home ecosystem.
Under the hood, each node uses the awesome TP-Link Smart Home API.
$ npm install node-red-contrib-tplink-smarthome
or you can use the Palette Manager in Node-RED.
Parameters
Name: Type in the name of the host manually or keep the default device name
Device IP: Type in the Device IP address manually or press the button to retreive all locally available plug devices
Poll interval: Interval that is used to poll availability of devices (min 500ms / recommended between 5000ms and 10000ms)
Event poll interval: Interval that is used to poll active devices for events (min 500ms / recommended between 1000ms and 3000ms)
Inputs
payload: string | boolean
On/Off
true: Turn on the device.
false: Turn off the device.
Commands
getInfo: Fetch the device information.
getMeterInfo: Fetch the current device consumption.
clearEvents: Unsubscribe events.
eraseStats: Clear all the meter statistics.
Events
getMeterEvents: Subscribe to meter information events.
getInfoEvents: Subscribe to information events.
getPowerUpdateEvents: Subscribe to power on/off events.
getInUseEvents: Subscribe to device usage events.
getOnlineEvents: Subscribe to online/offline events.
Multiple events can be used as a list separated with the | character.
Become my patron
Version: 0.1.1
Updated 9 years, 7 months ago
17 in the last week
  • smart-plug
  • smart-bulb
  • tplink
  • kasa
  • iot
  • hs100
  • hs105
  • hs110
  • hs200
  • lb100
  • lb110
  • lb120
  • lb130
  • home
  • smart
  • smartplug
  • smartswitch
  • smartbulb
