node-red-contrib-tplink-iot 0.1.8
A collection of Node-RED nodes for TP-Link smart-home devices.
npm install node-red-contrib-tplink-iot
TP-Link Smart Home Node-Red Nodes
GitHub release NPM Version GitHub last commit
Node version GitHub repo size in bytes CodeFactor
Github All Releases Liberapay receiving
npm GitHub contributors contributions welcome
This is a collection of Node-RED nodes that allow you control smart plugs and bulbs from the TP-Link smart home ecosystem.
This is a fork of so inspiring node-red-contrib-tplink-smarthome with added functionality.
Under the hood, each node uses the awesome TP-Link Smart Home API.
$ npm install node-red-contrib-tplink-iot
or you can use the Palette Manager in Node-RED.
Parameters
Name - Type in the name of the host manually or keep the default device name
Device IP - Type in the Device IP address manually or press the button to retrieve all locally available plug devices
Poll interval - Interval that is used to poll availability of devices (>500ms / Recommended 5000-10000ms)
Event poll interval - Interval that is used to poll active devices for events (>500ms / Recommended 1000-3000ms)
Inputs
payload: string | boolean
On/Off
true - Turn on the device.
false - Turn off the device.
switch - Toggle opposite power state of the device.
Brightness
brightness:[value 1-100]
Example: Send payload as brightness:25 to set brightness of the bulb to 25%.
Temperature
temperature:[value 2700-6500]
Example: Send payload as temperature:5000 to set temperature of the bulb to 5000k.
Commands
getInfo - Fetch the device information.
getCloudInfo - Fetch the device information from the cloud.
getQuickInfo - Fetch most popular proprieties, such as username, device consumption, mode, lighting state, and many more.
getMeterInfo - Fetch the current device consumption.
clearEvents - Unsubscribe events.
eraseStats - Clear all the meter statistics.
Events
getMeterEvents - Subscribe to meter information events.
getInfoEvents - Subscribe to information events.
getPowerUpdateEvents - Subscribe to power on/off events.
getInUseEvents - Subscribe to device usage events.
getOnlineEvents - Subscribe to online/offline events.
Multiple events can be used as a list separated with the | character.
For developers
Nodes are made available to Node-RED in .js files minimized by Google's Closure Compiler.
HOWEVER an original, up-to-date, file is included as .bak.js to easily modify code. Must be recompiled or copied as .js for code to reflect in you app.
This repo. is (mainly) coded on Node 10.3.0 with Node-RED 0.18.7 on Windows 10 Home Build 17134.81. Runs succesfully in a Raspberry Pi 3 Model B+ on standard Raspbian Stretch's Node 0.10.29 and matching Node-RED.
https://nodei.co/npm/node-red-contrib-tplink-iot.png?downloads=true&downloadRank=true&stars=true
Version: 0.1.8
Updated 9 years, 2 months ago
23 in the last week
  • smart-plug
  • smart-bulb
  • tplink
  • tp-link
  • kasa
  • iot
  • hs100
  • hs105
  • hs110
  • hs200
  • lb100
  • lb110
  • lb120
  • lb130
  • lb200
  • lb230
  • home
  • smart
  • smartplug
  • smartswitch
  • smartbulb
  • Barney Rubble
  • Raj Amal
