node-red-contrib-toypad 1.0.3
Nodes to read NFC data from the lego dimensions toypad
npm install node-red-contrib-toypad
this is a collection of nodes to control the Lego Dimensions Toypad NFC reader via Node-RED.
Currently supported
✅ Reading NFC UIDs
✅ Detecting the different reader regions for the tags
✅ Controlling the RGB LED color for every section
✅ Fading LEDs
✅ Flashing LEDs
❌ Reading payloads
❌ Writing payloads
Linux
libusb needs to be installed. You also might want to create a udev rule.
sudo vim /etc/udev/rules.d/99-dimensions.rules
SUBSYSTEM=="usb", ATTR{idVendor}=="0e6f", ATTR{idProduct}=="0241", MODE="0666"
Node-RED inside Docker
This needs some attention as you can't access USB right away. I've found success in adding the following lines to my docker-compose.yaml:
    devices:
      - '/dev/bus:/dev/bus'
Version: 1.0.3
Updated 2 years, 4 months ago
  • toypad-color
  • toypad-tag-event
  • lego
  • dimensions
  • toypad
  • nfc
