node-red-contrib-totaliser 0.0.11
Node-RED nodes to total an input value over a period of time
npm install node-red-contrib-totaliser
Version
Copyright 2018 iaconnects under the BSD-3-Clause license.
The totaliser node can be used to create a periodic total of an input value. This node works in three possible ways:
  • Accumulating Sum - Outputs the running total of the sum of every input at the end of every period. The total is not reset to zero at the start of the period
  • Sum - Outputs the sum of every input at the end of every period. The total is reset to zero at the start of the period
  • Difference - Outputs the difference between the last and the first inputs of a period, at the end of every period. This mode is useful when the input is an accumulating value such as a meter reading.
Version: 0.0.11
Updated 7 years, 2 months ago
License: Commercial
Rating: 3.0 2
38 in the last week
  • totaliser
  • totaliser
  • totalizer
