node-red-contrib-ton-toff 1.0.1
Node-RED TON/TOFF timer - On-Delay and Off-Delay timer functions
npm install node-red-contrib-ton-toff
Node-RED timer node with configurable on-delay and off-delay (TON/TOFF).
  • Configurable on-delay (TON)
  • Configurable off-delay (TOFF)
  • Delay units: ms / s / min
  • Live countdown in node status
  • Extended truthy/falsy evaluation
Behavior
  • Input becomes truthy → waits onDelay → Output true
  • Input becomes falsy → waits offDelay → Output false
  • Input changes while timer is running → cancel timer, start new timer
  • Same input while timer is running → timer continues (no reset)
  • Delay = 0 → immediate reaction (no timer)
Examples
onDelay=1s, offDelay=1s:
Input 1 → waits 1s → Output true
Input 0 → waits 1s → Output false
onDelay=2s, offDelay=0s:
Input 1 → waits 2s → Output true
Input 0 → immediately → Output false
Property Description Default
On Delay Turn-on delay 1
Off Delay Turn-off delay 1
Unit ms / s / min (for both) s
Input
msg.payload - Any value, evaluated as truthy/falsy:
Falsy (= OFF): false, 0, "", null, undefined, NaN, "false", "0", "off"
Truthy (= ON): Everything else: true, 1, "on", "hello", 42, etc.
Runtime Overrides
msg.onDelay Overrides onDelay temporarily (in configured unit)
msg.offDelay Overrides offDelay temporarily (in configured unit)
msg.bypassOn true = immediate ON without delay
msg.bypassOff true = immediate OFF without delay
Output
{ "payload": true }
The original msg object is forwarded, only payload is overwritten.
Use Cases
Application onDelay offDelay
Motion detector 0 30s
Debounce 500ms 0
Soft start/stop 2s 5s
Node Status
  • Idle - Waiting for first input
  • ON in 5s... - On-delay running
  • OFF in 3s... - Off-delay running
  • ON - Output is true
  • OFF - Output is false
Author
sr.rpo
MIT
Version: 1.0.1
Updated 7 months, 3 weeks ago
220 in the last week
  • ton-toff
  • timer
  • ton
  • toff
  • delay
  • on-delay
  • off-delay
  • plc
