node-red-contrib-toggle 0.1.1
Toggle switch node for Node-red
npm install node-red-contrib-toggle
Toggle switch node for Node-red.
This node is a companion for any switch (physical or virtual), storing its state and providing toggle operation without need of using function nodes or flow/global variables.
node-appearance
Fig. 1: Node appearance
In Node-RED (preferred)
  • Via Manage Palette -> Search for "node-red-contrib-toggle"
In a shell
  • go to the Node-RED installation folder, e.g.: ~/.node-red
  • run npm install node-red-contrib-toggle
Node Configuration
The node configuration sets the active on/off/toggle keywords as well as optional topic names.
node-settings
Fig. 2: Node properties
ON value / OFF value / Toggle value
These attributes can be of type
  • string
  • number
  • boolean
They are set to the values you want to be the keywords within msg.payload when the actions switch to ON, switch to OFF and toggle shall take place (execution command).
Remark: If you do not set a value to one of the attributes the according method (e.g. switch ON) can not be executed by the node (it needs a value to compare...).
On/Off topic resp. Toggle topic (optional)
If you set the topic attributes to a value, the input msg needs to contain the same topic name to execute On/Off resp. toggle in addition to the msg.payload value containing the execution command.
Pass through ON/OFF messages
The node has three pass through modes:
  • No - means that node sends an output msg only when state is toggled. ON/OFF input messages just update internal state of the node.
  • If changed - sends an output msg for ON/OFF input message only once it differs from the previous state. And obviously message is always sent for "toggle" message.
  • Always - the output msg is always sent as a reaction on an input msg.
Input
The input msg.payload contains the execution command to the node.
The value needs to be identical to the values you configured in the configuration dialog.
If a (string) value is set to the configuration attributes On/Off topic or Toggle topic, the msg.topic property must contain the same string value to execute the command given in msg.payload.
An example msg contents is shown for On/Off topic = "onofftopic":
node-settings
Fig. 3: Example msg when using topics
Output
The input msg is forwarded to the output, if a valid switch command was detected.
The configuration attribute pass through ON/OFF messages is taken into account.
Node status
The node status signals:
  • If the switch status is on it shows a green dot with the text ON.
  • If the switch status is off it shows a red dot with the text OFF.
Initially it shows no state.
Examples
Remark: Example flows are present in the examples subdirectory. In Node-RED they can be imported via the import function and then selecting Examples in the vertical tab menue.
Example 1: Basic ON/OFF usage
This example shows the basic usage of the on and off commands.
The configuration is set to boolean true resp. false to switch on resp. switch off and no toggle option.
BasicUsage.json
Fig. 4: Basic usage example
Example 2: Basic toggle usage
This example shows the basic usage of the toggle command.
The configuration is set to boolean true resp. false and to toggle with all other msg.payload/msg.topic combinations.
ToggleUsage.json
Fig. 5: Toggle usage example
Example 3: Usage with topics
This example shows the usage of topics.
The configuration is set to strings (switchON, switchOFF) to switch on resp. off and a string (toggleSTATE) to toggle the switch.
Additionally, the topics are set to onofftopic (for the commands switchON and switchOFF) and to toggletopic for the toggle operation (command toggleSTATE).
TopicUsage.json
Fig. 6: Topic usage example
Version history
v0.1.1 Toggle example added to docu
v0.1.0 Docu rework
v0.0.2 Docs updated
v0.0.1 Initial release
Credits
Version: 0.1.1
Updated 6 years, 5 months ago
Rating: 5.0 4
206 in the last week
  • toggle
  • node
  • toggle
  • switch
  • power
