node-red-contrib-to-markdown 1.1.3
Parse HTML to Markdown
npm install node-red-contrib-to-markdown
HTML to Markdown NodeRED Node
Buy me a beer
A Node-RED node that converts HTML content into Markdown format.
  • Converts HTML tags like <h1> to #, <p> to paragraph text, <ul>/<ol> to lists, and <a> to Markdown links.
  • Useful for transforming rich text content into Markdown for storage, APIs, or display in Markdown renderers.
From your Node-RED user directory (~/.node-red):
Add the to-markdown node to your flow. Pass HTML content to the payload property, and the node will output the corresponding Markdown.
Example Input
  "payload": "<h1>Title</h1><p>This is a paragraph.</p><ul><li>Item 1</li><li>Item 2</li></ul><a href='https://example.com'>Link</a>"
Example Output
# Title
- Item 1
- Item 2
[Link](https://example.com)
Node Properties
This node does not require any configuration. It simply reads the incoming msg.payload as HTML and outputs Markdown.
Compatibility
  • Requires Node.js 20+
  • Compatible with Node-RED 3.x+
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at LICENSE.
Version: 1.1.3
Updated 1 year, 6 months ago
  • to-markdown
  • markdown
  • html
