node-red-contrib-tinkerforge-2 0.0.35
Node-RED nodes to access Tinkerforge sensors
npm install node-red-contrib-tinkerforge-2
A set of Node-RED nodes to access Tinkerforge bricklets
These nodes make use of Tinkerforge's javascript library to connect to a local brickd instance or to a remote instance (via Ethernet/WiFi brick)
From npm
Supported Bricklets
Currently there are nodes for the following bricklets
  • AmbientLight
  • AnalogOut
  • Barometer
  • CO2
  • DistanceIR
  • DistanceIRV2
  • DistanceUS
  • DualRelay
  • HallEffect
  • Humidity
  • HumidityV2
  • IndAnalogOut
  • IndDigital4In
  • IndDigital4Out
  • IndDigital4OutV2
  • IndDualAnalogIn
  • IO4
  • LaserRange
  • LEDStrip
  • Line
  • LinearPoti
  • Moisture
  • Motion
  • PiezoSpeaker
  • PTC
  • RemoteSwitch
  • RotaryPoti
  • SoundIntensity
  • Temperature
  • TemperatureIR
  • Tilt
  • VoltageCurrent
Adding more should be pretty trivial, these are just the bricks I currently access to for testing
Apache 2.0
Version: 0.0.35
Updated 6 years ago
10 in the last week
  • TinkerForgeConfig
  • TinkerForge AmbientLight
  • TinkerForge AnalogOut
  • TinkerForge Barometer
  • TinkerForge CO2
  • TinkerForge DistanceIR
  • TinkerForge DistanceIRV2
  • TinkerForge DistanceUS
  • TinkerForge DualRelay
  • TinkerForge HallEffect
  • TinkerForge Humidity
  • TinkerForge HumidityV2
  • TinkerForge IndAnalogOut
  • TinkerForge Digital-In
  • TinkerForge Digital-Out
  • TinkerForge Digital-OutV2
  • TinkerForge IndDualAnalogIn
  • TinkerForge IO-4
  • TinkerForge LaserRange
  • TinkerForge LEDStrip
  • TinkerForge Line
  • TinkerForge LinearPoti
  • TinkerForge Moisture
  • TinkerForge Motion
  • TinkerForge PiezoSpeaker
  • TinkerForge PTC
  • Tinkerforge RemoteSwitch
  • TinkerForge RotaryPoti
  • TinkerForge SoundIntensity
  • TinkerForge Temperature
  • TinkerForge TemperatureIR
  • TinkerForge Tilt
  • TinkerForge VoltageCurrent
  • tinkerforge
  • node-red-contrib-tinkerforge-2
