node-red-contrib-timer-events 0.1.4
An enhanced Node-RED timer node with variable delay, pause/resume, persistent state, cooldown and configurable reporting.
npm install node-red-contrib-timer-events
timer-events
A countdown timer node for Node-RED with a purpose-built four-output event model. Every command — successful, redundant, or blocked — is observable as a structured event, so flows can react to exactly what happened without guesswork.
Derived from stoptimer-varidelay-plus.
Why this node
Most timer nodes tell you when the timer fires. This one tells you everything: when it started, restarted, stopped, expired, paused, resumed, was locked, was blocked, or had its time adjusted — each as a tagged event with a consistent message envelope describing the timer's full state at that moment.
Outputs
# Output Fires on
1 Start A true stopped/expired → running transition. Nothing else.
2 Stop A genuine stop command or natural expiry. Nothing else.
3 Query An incoming query message, or a Heartbeat tick.
4 Events Every event, including copies of Start/Stop and every ignored/blocked command.
Outputs 1 and 2 never carry a blocked or redundant message — anything that didn't truly happen appears only on output 4, tagged msg.ignored: true.
Features at a glance
  • Variable delay — override duration per message via msg.delay / msg.units
  • Control commands — stop, pause, resume, query, lock, unlock, disable, enable, adjusttime, settime, setduration (all case-insensitive)
  • Event envelope — every output message carries timerEvent, timerState, remainingTime, elapsedTime, timerDuration, ignored, source, and more
  • Ignored-message threshold actions — automatically stop, pause, restart, add time, or emit a warning when enough messages are ignored during a run
  • Heartbeat — periodic status snapshots on the Query output for monitoring long-running timers
  • Cooldown — refuse new starts for a fixed period after a natural expiry
  • Persistence — resume running, paused, or cooling-down timers across deploys and Node-RED restarts
From your Node-RED user directory (typically ~/.node-red):
Or via the Node-RED palette manager. The node appears in the function category as Timer with Events.
Documentation
Full documentation — configuration reference, event taxonomy, command details, persistence behavior, example flows, and troubleshooting — lives in the project wiki. The node's built-in help panel in the Node-RED editor also covers everyday usage.
Licensed under the Apache License 2.0.
Modifications copyright (C) 2025 mchristegh. Derived from stoptimer-varidelay-plus — modifications copyright (C) 2020 hamsando; original copyright jbardi.
Version: 0.1.4
Updated 4 months, 1 week ago
Rating: 4.5 2
14 in the last week
  • timer
  • delay
  • stoptimer
  • cooldown
  • pause
  • resume
  • persist
