node-red-contrib-timer 1.0.6
timer node
npm install node-red-contrib-timer
platform npm package version license Npm package total downloads github-issues
node-red-contrib-timer is a rudementary timer.
Getting Started
Prerequisites
Install via Node-RED Manage Palette
Install via npm
$ cd ~/.node-red
$ npm install node-red-contrib-timer
# then restart node-red
Configuration Pane
properties edit dialog
Node input
Start and stop with msg.payload:
  • true starts the timer.
  • false stops the timer.
Set expiry time with msg.payload:
  • int sets countdown in seconds.
Examples
Using topic to filter payload when cancelled
When no topic property is defined in the node, the incoming topic is copied over to the output. This can be used to filter out the expiry payload when the timer is cancelled.
canceling expiry
[{"id":"38a5c6e.079893a","type":"tab","label":"ignore cancel","disabled":false,"info":""},{"id":"b5e83fc7.69dc8","type":"debug","z":"38a5c6e.079893a","name":"state","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":670,"y":140,"wires":[]},{"id":"6fb05b68.183e3c","type":"debug","z":"38a5c6e.079893a","name":"timer","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":670,"y":200,"wires":[]},{"id":"72a3e721.0cc288","type":"inject","z":"38a5c6e.079893a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cancel","payload":"false","payloadType":"bool","x":134,"y":196,"wires":[["d96dea31904032b8"]]},{"id":"84f20a87.3a0308","type":"inject","z":"38a5c6e.079893a","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":154,"y":136,"wires":[["d96dea31904032b8"]]},{"id":"48ce8bab.3c0634","type":"function","z":"38a5c6e.079893a","name":"ignore cancel","func":"if (msg.topic != 'cancel') {\n    return msg;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":140,"wires":[["b5e83fc7.69dc8"]]},{"id":"225ff94.486e486","type":"comment","z":"38a5c6e.079893a","name":"Incoming message topic can be copied over to the output.","info":"","x":250,"y":40,"wires":[]},{"id":"d96dea31904032b8","type":"timer-node","z":"38a5c6e.079893a","name":"","topic":"","timer":"5","payloadOn":"false","payloadOnType":"bool","payloadOff":"true","payloadOffType":"bool","x":310,"y":160,"wires":[["48ce8bab.3c0634"],["6fb05b68.183e3c"]]},{"id":"bd55ac20a78e44fc","type":"comment","z":"38a5c6e.079893a","name":"This example uses a function node to filter out the expiry payload when timer is cancelled.","info":"","x":350,"y":80,"wires":[]}]
Message property propagation
Properties defined in the incoming msg object are copied over to the outputs. The payload is changed and topic (if defined in the node).
msg propagation
[{"id":"8af9695e.73126","type":"tab","label":"msg property propagation","disabled":false,"info":""},{"id":"43d996ab.f0fa48","type":"inject","z":"8af9695e.73126","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"foo","v":"bar","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"object copying","payload":"true","payloadType":"bool","x":190,"y":140,"wires":[["1421f228d1843b9b"]]},{"id":"c830b39e.c0c1","type":"debug","z":"8af9695e.73126","name":"timer","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":610,"y":280,"wires":[]},{"id":"3a0fe194.c88de6","type":"debug","z":"8af9695e.73126","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":630,"y":140,"wires":[]},{"id":"40a132b2.d74a8c","type":"debug","z":"8af9695e.73126","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"foo","targetType":"msg","statusVal":"payload","statusType":"auto","x":620,"y":200,"wires":[]},{"id":"d2e4815a.235dd","type":"debug","z":"8af9695e.73126","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"topic","targetType":"msg","statusVal":"payload","statusType":"auto","x":620,"y":80,"wires":[]},{"id":"3b550efa.cdb4aa","type":"inject","z":"8af9695e.73126","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"foo","v":"cis boom bah","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"object copying cancelled","payload":"false","payloadType":"bool","x":160,"y":220,"wires":[["1421f228d1843b9b"]]},{"id":"8d7ff426.ad474","type":"comment","z":"8af9695e.73126","name":"Message properties are copied over to the output.","info":"","x":200,"y":40,"wires":[]},{"id":"1421f228d1843b9b","type":"timer-node","z":"8af9695e.73126","name":"","topic":"","timer":"5","payloadOn":"false","payloadOnType":"bool","payloadOff":"true","payloadOffType":"bool","x":410,"y":180,"wires":[["d2e4815a.235dd","3a0fe194.c88de6","40a132b2.d74a8c"],["c830b39e.c0c1"]]},{"id":"c81e85b84437fd8a","type":"comment","z":"8af9695e.73126","name":"only msg.payload is changed.","info":"","x":140,"y":80,"wires":[]}]
Override msg.topic in properties
When topic is defined in the node properties, incoming msg.topic is overriden.
topic overriding
[{"id":"3f3d6774.cce2f","type":"tab","label":"topic override","disabled":false,"info":""},{"id":"c11b7d9c.021958","type":"inject","z":"3f3d6774.cce2f","name":"","props":[{"p":"topic","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"ignored","payload":"true","payloadType":"bool","x":150,"y":140,"wires":[["bf0781a1230c42ac"]]},{"id":"3706780.96a0c08","type":"inject","z":"3f3d6774.cce2f","name":"","props":[{"p":"topic","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"ignored","payload":"false","payloadType":"bool","x":150,"y":220,"wires":[["bf0781a1230c42ac"]]},{"id":"5d48ca08.c9c664","type":"debug","z":"3f3d6774.cce2f","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"topic","targetType":"msg","statusVal":"payload","statusType":"auto","x":560,"y":100,"wires":[]},{"id":"4e8c7759.a6b17","type":"debug","z":"3f3d6774.cce2f","name":"timer","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":550,"y":260,"wires":[]},{"id":"edfec9d6.4e066","type":"debug","z":"3f3d6774.cce2f","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":570,"y":160,"wires":[]},{"id":"d9fa71cd.4df948","type":"comment","z":"3f3d6774.cce2f","name":"When topic is defined in node properties it overrides the incoming message topic.","info":"","x":320,"y":40,"wires":[]},{"id":"bf0781a1230c42ac","type":"timer-node","z":"3f3d6774.cce2f","name":"","topic":"override topic","timer":"5","payloadOn":"false","payloadOnType":"bool","payloadOff":"true","payloadOffType":"bool","x":350,"y":160,"wires":[["5d48ca08.c9c664","edfec9d6.4e066"],["4e8c7759.a6b17"]]}]
Version: 1.0.6
Updated 4 years ago
79 in the last week
  • timer-node
  • timer
  • timing
  • sequencing
  • duty cycle
  • delay
