node-red-contrib-time-validator 0.0.5
A Node-RED node for validating schedules and time ranges.
npm install node-red-contrib-time-validator
Node-RED Contrib Time Validator
Description
The Time Validator is a custom Node-RED node designed to validate whether the current date and time fall within a specific range or match predefined conditions. This node is useful for scheduling, flow control, and dynamic validation based on user-defined time periods.
  • Custom Time Validation: Supports multiple validation types (specific, annual, day, week) to check if the current date/time falls within a configured range.
  • Flexible Configuration: Allows setting multiple date blocks with start/end times and activation status.
  • Priority-Based Evaluation: Evaluates validation rules in the order of priority: specific → annual → day → week.
  • Output Custom Results: Outputs a structured object with validation status and details for further flow processing.
Install via NPM in your Node-RED directory:
Or globally:
npm install -g node-red-contrib-time-validator
How to Use
  1. Drag the Time Validator node into your Node-RED flow.
  2. Configure validation blocks with the following options:
    • Validation Type: Choose between specific, annual, day, or week.
    • Time Range: Define start and end times.
    • Activation Status: Enable or disable specific blocks.
  3. Connect the node to your flow to filter or process messages based on the validation result.
Inputs
  • Message Object (msg):
    • The node processes the incoming message to determine if it passes validation. Input messages can include additional parameters if needed.
Outputs
  • Output 1 (Valid): The message is passed through this output if the conditions are met.
  • Output 2 (Invalid): The message is passed through this output if the conditions are not met.
  • Message Object (msg.result): Returns a detailed validation result with the following structure:
      "status": "valid",
      "value": "2024-11-20",
      "startTime": "09:00",
      "endTime": "17:00",
      "isActive": true,
      "blockType": "specific",
      "checkedAt": "2024-11-20T14:34:00Z"
Example Flow
    "id": "3b7630dbe77d213d",
    "type": "inject",
    "z": "f6f2187d.f17ca8",
    "props": [{
        "p": "payload"
        "p": "topic",
        "vt": "str"
    "repeat": "",
    "crontab": "",
    "once": false,
    "onceDelay": 0.1,
    "topic": "",
    "payload": "",
    "payloadType": "date",
    "x": 220,
    "y": 160,
        "8f89bfb23747b71a"
    "id": "a308aaf71704f15f",
    "type": "debug",
    "name": "debug 1",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "true",
    "targetType": "full",
    "statusVal": "",
    "statusType": "auto",
    "x": 660,
    "y": 140,
    "id": "4cd8ce4dd9f6da6e",
    "type": "debug",
    "name": "debug 2",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "true",
    "statusVal": "",
    "x": 660,
    "y": 180,
    "id": "8f89bfb23747b71a",
    "type": "time-validator",
    "active": "true",
    "timezone": "-3",
    "dateBlocks": [{
        "type": "week",
        "value": [
          "monday",
          "tuesday",
          "wednesday",
          "thursday",
          "friday"
        "isActive": "true",
        "startTime": "18:00",
        "endTime": "22:00"
        "type": "day",
        "value": "21",
        "isActive": "true",
        "startTime": "20:30",
        "endTime": "21:30"
        "type": "annual",
        "value": "21/11",
        "isActive": "true",
        "startTime": "20:00",
        "endTime": "22:00"
        "type": "specific",
        "value": "2024-11-21",
        "isActive": "false",
        "endTime": "22:00"
    "x": 460,
    "y": 160,
        "a308aaf71704f15f"
        "4cd8ce4dd9f6da6e"
Contribution
  1. Fork the repository.
  2. Create a new branch (git checkout -b feature-name).
  3. Commit your changes (git commit -m 'Add new feature').
  4. Push your branch (git push origin feature-name).
  5. Open a Pull Request.
Distributed under the MIT License. See the LICENSE file for more details.
Contact
Lucas Santos - [email protected]
GitHub Repository: https://github.com/lucassantossouza/node-red-contrib-time-validator
Version: 0.0.5
Updated 2 years, 1 month ago
Rating: 5.0 5
2 in the last week
  • node-red-node
  • time
  • schedule
  • range
  • validator
