node-red-contrib-time-switch 1.1.7
Routes messages depending on the current time.
npm install node-red-contrib-time-switch
Project Stage License
Build Status Maintenance
Maintainability Coverage Status Dependencies Status Known Vulnerabilities
Node-RED Time Switch (Contribution package)
A simple Node-RED node that routes messages depending on the time or sun position.
Node
It is possible to specify a time, the sun position (requires your geo location to be configured) or even a value of the message, the flow or the instance of node red.
Config
Change directory to your node red installation and run the following command:
NPM
The times can be a 24 hour time or a suncalc event:
Time Description
00:00 ... 23:59 24hr time (without seconds)
sunrise sunrise (top edge of the sun appears on the horizon)
sunriseEnd sunrise ends (bottom edge of the sun touches the horizon)
goldenHourEnd morning golden hour (soft light, best time for photography) ends
solarNoon solar noon (sun is in the highest position)
goldenHour evening golden hour starts
sunsetStart sunset starts (bottom edge of the sun touches the horizon)
sunset sunset (sun disappears below the horizon, evening civil twilight starts)
dusk dusk (evening nautical twilight starts)
nauticalDusk nautical dusk (evening astronomical twilight starts)
night night starts (dark enough for astronomical observations)
nadir nadir (darkest moment of the night, sun is in the lowest position)
nightEnd night ends (morning astronomical twilight starts)
nauticalDawn nautical dawn (morning nautical twilight starts)
dawn dawn (morning nautical twilight ends, morning civil twilight starts)
{{msg.fieldName}} Access a field of the message (mustache template syntax)
{{flow.fieldName}} Access a field of the flow (mustache template syntax)
{{global.fieldName}} Access a global field (mustache template syntax)
Placeholders with prefix msg, flow or global are replaced by the corresponding field value.
Offsets
The start and end time can have an offset. You can use fields here aswell.
This is specified in minutes:
  • Negative numbers are bringing the time back. E.g. if the time is dusk and offset is -60, the start time will be 60 minutes before dusk.
  • Positive numbers are delaying the time by the specified number of minutes
The offset also supports placeholders:
Placeholder Description
Geo location
Specify the latitude and longitude of your geo location or use one of the followng placeolders as value:
Version: 1.1.7
Updated 1 year, 8 months ago
Rating: 4.2 5
102 in the last week
  • time-switch
  • router
  • switch
  • time
  • sun events
