node-red-contrib-time-based-dimmer 0.8.2
A time based dimmer for node-red. It can be used to increase/descrease a numerical value where one event starts the process (like pressing a button) and another event (like releasing the button) stops it.
npm install node-red-contrib-time-based-dimmer
Node-Red time based dimmer
This node allows to add a dimmer to your node-red that will be triggered by start and stop commands. It was originally designed to work with the IKEA Tradfri Switch CB10 which was connected over mqtt using zigbee2mqtt. We will ignore the "simple clicks" and only take a look at the dimming. When holding one of the keys down, it will trigger "brightness_up" or "brightness_down" and after releasing the button, it will trigger "brightness_stop". This dimmer will "catch" these commands and change its value based on how long the button is being pressed.
In version 0.5.0 a second node called "one-button-dimmer" was added. The one button dimmer works pretty much like the time-based-dimmer but it does not require different commands to dimm brighter or darker but it will use the same button (and the same commands) to take turns of turning the light brighter or darker. This can for example be used with the round Xiaomi Aqara switch.
Run command on Node-RED installation directory.
or run command for global installation.
npm install -g node-red-contrib-time-based-dimmer
The node can be used rather similar to the slider from the dashboard. It will use any numerical value it gets as its current state. The main difference is that it will also accept some commands. The keywords for the commands are configurable. The commands will trigger the dimmers value to increase or decrease over time. The only thing left to do is connect the output of the dimmer to the brightness of a light.
Settings
There are several required settings in the node.
  • Interval: the number of milliseconds between the dimming steps
  • Step: the amount that will be added or substracted on every step
  • MinValue: the minimum value for the dimmer. If the values gets lower than the minimum, the value will be set to the minimum and the dimming process will be stopped.
  • MaxValue: the maximum value for the dimmer. If the values gets higher than the maximum, the value will be set to the maximum and the dimming process will be stopped.
  • Commands: If a string is being used as input for the dimmer, the dimmer will compare the string to the commands it knows. If a command can be found, it will be triggered.
    • Start Increase Command: The dimmer will start to increase its value
    • Stop Increase Command: The dimmer will keep its state
    • Start Decrease Command: The dimmer will start to decrease its value
    • Stop Decrease Command: The dimmer will keep its state
The one button dimmer has slightly simpler settings as there are only two commands.
  • Start Command: The dimmer will start to increase or decrease its value
  • Stop Command: The dimmer will keep its state
For developers
If you want to add changes to the code, please feel free but it would be nice if you created a pull request if the feature would be useful to other users.
Automated Tests
After changing anything, please make sure the jest tests do still execute by running:
yarn test
Ideally you would also add tests for the changes you made.
Version: 0.8.2
Updated 7 years, 2 months ago
Rating: 4.4 5
58 in the last week
  • time-based-dimmer
  • one-button-dimmer
