node-red-contrib-threshold-hysteresis 1.0.0
Node-RED node for hysteresis logic - outputs boolean based on high/low thresholds
npm install node-red-contrib-threshold-hysteresis
node-red-contrib-hysteresis
A Node-RED node for hysteresis (deadband) logic - prevents rapid on/off switching when values hover around a threshold.
  • Simple configuration: Setpoint + Hysteresis (±)
  • Two modes: High (ON when above) or Low (ON when below)
  • Configurable initial state
  • Real-time status display in editor
  • Live threshold preview while editing
Property Description Example
Setpoint Target value 22
Hysteresis (±) Deadband range 1
Mode When to turn ON High / Low
Initial State Starting state undefined
Mode: High (Cooling)
Use when output should be ON when temperature is above setpoint.
Setpoint: 22, Hysteresis: 1
→ ON when value ≥ 23
→ OFF when value ≤ 21
Mode: Low (Heating)
Use when output should be ON when temperature is below setpoint.
→ ON when value ≤ 21
→ OFF when value ≥ 23
How It Works
         OFF zone          Deadband           ON zone
  ────────────────── 21 ════════════ 23 ──────────────
                     │   (no change)  │
               Low Threshold    High Threshold
                 (22 - 1)         (22 + 1)
Input
  • msg.payload - Numeric value (temperature, pressure, humidity, etc.)
Output
  • msg.payload - Boolean (true or false)
  • msg.value - The input value
  • msg.previousState - State before evaluation
  • msg.setpoint - Configured setpoint
  • msg.hysteresis - Configured hysteresis
  • msg.mode - Configured mode
Example Output
  "payload": true,
  "value": 24.5,
  "previousState": false,
  "setpoint": 22,
  "hysteresis": 1,
  "mode": "high"
Example Sequences
Cooling (Mode: High)
Input Output Reason
20 OFF Below 21
22 OFF Between thresholds, stays OFF
24 ON Above 23
22 ON Between thresholds, stays ON
20 OFF Below 21
Heating (Mode: Low)
Input Output Reason
24 OFF Above 23
20 ON Below 21
24 OFF Above 23
Use Cases
  • HVAC Control: Prevent heating/cooling from toggling rapidly
  • Pump Control: Avoid frequent pump starts when water level fluctuates
  • Alarm Systems: Reduce false alarms from sensor noise
  • Fan Control: Smooth fan on/off behavior based on temperature
Author
sr.rpo
MIT
Version: 1.0.0
Updated 8 months ago
128 in the last week
  • hysteresis
  • hysteresis
  • threshold
  • temperature
  • control
