node-red-contrib-thingsboard-rest-api-auth 3.3.3
Node-RED node for thingsboard-rest-api-auth
ThingsBoard open-source IoT platform REST API documentation.
To install the stable version use the Menu - Manage palette - Install
option and search for node-red-contrib-thingsboard-rest-api-auth, or run the following
command in your Node-RED user directory, typically ~/.node-red
npm install node-red-contrib-thingsboard-rest-api-auth
Methods
POST /api/auth/login
Login method used to authenticate user and get JWT token data.
Value of the response token field can be used as X-Authorization header value:
X-Authorization: Bearer $JWT_TOKEN_VALUE.
body :
Accept : 'application/json'
Content-Type : 'application/json'
Apache License Version 2.0
https://github.com/thingsboard/thingsboard/blob/master/LICENSE
