node-red-contrib-thermia 1.0.4
Node to access Thermia Genesis heat-pump
npm install node-red-contrib-thermia
Node-red node to integrate with Thermia Genesis heat-pumps. Based on webapp https://www.online-genesis.thermia.se/
Quick start
Install the component
Enter your credentials for https://www.online-genesis.thermia.se/ in node configuration screen. It would be a good practice to create a sepearate user for the component.
If you have severeal pumps
Inputs
msg.action
setTemperature - set point for the room temperature. Parms in payload
msg = {
    action: 'setTemperature',
    payload: 22               // set point for the room temperature
setHotWater - set boiler status
msg = {
    action: 'setHotWater',
    payload: false               // turn boiler off
Any other input
Status update
Outputs
Status of the heat pump
msg.payload = {
    hotWaterTemperature: 54,        // current hot water temperature
    heatingEffect: 22,              // current set point for the room temperature
    outdoorTemperature: 29,         // outdoor sensor value
    hotWaterStatus: false           // boiler off
Version: 1.0.4
  • thermia-genesis
