node-red-contrib-testmonitor 1.0.0
A comprehensive Node-RED wrapper for TestMonitor API providing test case management, test runs, milestones, and test result operations for test automation workflows
npm install node-red-contrib-testmonitor
A comprehensive Node-RED wrapper for the TestMonitor API providing test case management, test runs, milestones, and test result operations for test automation workflows.
  • Complete TestMonitor API Coverage: Access all major TestMonitor endpoints
  • Authentication Management: Secure API key authentication with connection testing
  • Intelligent Caching: Configurable caching for improved performance
  • Error Handling: Comprehensive error reporting and status indicators
  • Flexible Input/Output: Support for both message properties and node configuration
  • Status Tracking: Visual feedback for all operations
From Node-RED Palette Manager
  1. Open Node-RED in your browser
  2. Go to Menu → Manage Palette
  3. Click the Install tab
  4. Search for node-red-contrib-testmonitor
  5. Click Install
From npm
Manual Installation
Quick Start
  1. Add Credentials: Drag a TestMonitor Credentials config node and configure your API details
  2. Add Operation Nodes: Drag TestMonitor nodes for your desired operations
  3. Configure Operations: Set up each node with the appropriate operation and parameters
  4. Connect and Deploy: Wire up your flow and deploy
Configuration node for API authentication and connection management.
Configuration:
  • Base URL: Your TestMonitor instance API URL
  • Project ID: Numeric ID of your TestMonitor project
  • API Key: Your TestMonitor API key (securely encrypted)
TestMonitor TestCase
Manage test cases with full CRUD operations.
Operations:
  • get - Retrieve a specific test case by ID
  • list - List all test cases (optionally filtered by folder)
  • create - Create a new test case
  • update - Update an existing test case
  • delete - Delete a test case
Input Parameters:
msg.payload = {
    testCaseId: 123,           // Required for get, update, delete
    name: "Test Login",        // Required for create
    testCaseFolderId: 45,      // Folder for organization
    expected_result: "Success", // Expected outcome
    instructions: ["Step 1", "Step 2"], // Test steps
    tags: ["smoke", "authentication"],   // Tags for categorization
    description: "Test description",     // Custom field
    expected_value: "true",             // Custom field
    skip_time: 99                       // Custom field
TestMonitor TestRun
Manage test runs and execution cycles.
Operations:
  • get - Retrieve test run details
  • list - List test runs (optionally filtered by milestone)
  • create - Create a new test run
  • update - Update test run properties
  • delete - Delete a test run
  • getTestCases - Get test cases in a test run
  • getTestResults - Get test results for a test run
  • addTestCases - Add test cases to a test run
  • openTestRun - Open test run for execution (set draft=false)
  • closeTestRun - Close test run for editing (set draft=true)
Input Parameters:
msg.payload = {
    testRunId: 456,           // Required for most operations
    milestoneId: 789,         // Required for create
    name: "Sprint 1 Testing", // Test run name
    test_case_ids: [1, 2, 3], // For addTestCases operation
    draft: true,              // Draft status
    users: [3],               // Assigned users
    tags: ["sprint1"]         // Tags
TestMonitor TestResult
Record and manage test execution results.
Operations:
  • get - Retrieve test result details
  • list - List test results (filtered by test run/case)
  • create - Create a new test result
  • update - Update test result
  • delete - Delete test result
  • addComment - Add comment to test result
  • addAttachment - Upload file attachment
  • ensureExists - Create or update test result
Input Parameters:
msg.payload = {
    testResultId: 789,        // Required for get, update, delete
    testCaseId: 123,          // Required for create
    testRunId: 456,           // Required for create
    statusId: "passed",       // Status: passed, failed, blocked, not_tested, retest
    description: "Test completed successfully",
    comment: "Additional notes", // For addComment
    filePath: "/path/to/file"    // For addAttachment
TestMonitor Milestone
Manage project milestones and releases.
Operations:
  • get - Retrieve milestone details
  • list - List all milestones in project
  • create - Create a new milestone
  • update - Update milestone properties
  • delete - Delete milestone
  • getTestRuns - Get test runs for milestone
  • getLastTestRun - Get the most recent test run
  • createTestRun - Create new test run under milestone
Input Parameters:
msg.payload = {
    milestoneId: 101,               // Required for most operations
    name: "Release 2.0",            // Milestone name
    milestoneTypeId: "release",     // Type: release, feature, iteration, plan, sprint, version
    description: "Major release",   // Description
    ends_at: "2024-12-31",         // End date (YYYY-MM-DD)
    testRunName: "Release Testing"  // For createTestRun
TestMonitor Project
Access project-level information and resources.
Operations:
  • get - Get project information
  • getMilestones - List project milestones
  • getMilestoneTypes - Get available milestone types
  • getTestSuites - List test case folders/suites
  • getTestCases - List all project test cases
  • getTestRuns - List project test runs
  • getCustomFields - Get custom field definitions
  • getRequirements - List project requirements
  • update - Update project settings
Input Parameters:
msg.payload = {
    milestoneId: 101,           // Filter test runs by milestone
    model: "test-cases",        // Model for custom fields
    filterTag: "api",           // Filter requirements by tag
    name: "Updated Project Name" // For update operation
Configuration Examples
Basic Test Execution Flow
// 1. Get test cases from folder
msg.testCaseFolderId = 45;
// 2. Create test run
msg.payload = {
    operation: "create",
    milestoneId: 101,
    name: "Automated Test Run",
    test_cases: [1, 2, 3, 4, 5]
// 3. Record test results
msg.payload = {
    operation: "ensureExists",
    testCaseId: 1,
    testRunId: 456,
    statusId: "passed",
Test Case Management
// Create test case
msg.payload = {
    name: "Verify User Login",
    expected_result: "User successfully logs in",
    instructions: [
        "Navigate to login page",
        "Enter valid credentials",
        "Click login button",
        "Verify dashboard loads"
    tags: ["authentication", "smoke"],
    description: "Verifies the user login functionality"
Milestone and Test Run Setup
// Create milestone
msg.payload = {
    milestoneTypeId: "sprint",
    description: "Sprint 3 development cycle",
    ends_at: "2024-03-31"
// Create test run under milestone
msg.payload = {
    operation: "createTestRun",
    milestoneId: 101,
    testRunName: "Sprint 3 Testing",
    draft: false
Authentication
The package uses Bearer token authentication with the TestMonitor API:
  1. Generate an API key from your TestMonitor account settings
  2. Configure the TestMonitor Credentials node with:
    • Your TestMonitor instance URL
    • Project ID
    • API key
  3. Use the "Test Connection" button to verify connectivity
Caching
All nodes support intelligent caching for read operations:
  • Default Duration: 5 minutes (300 seconds)
  • Configurable: Adjust cache duration per node
  • Automatic: Read operations are cached automatically
  • Cache Keys: Generated based on operation and parameters
Error Handling
The package provides comprehensive error handling:
  • Visual Status: Node status shows current operation state
  • Error Messages: Detailed error information in Node-RED debug
  • Graceful Degradation: Failed operations don't crash flows
  • Validation: Input validation with helpful error messages
Status Indicators
Nodes display status using colored dots:
  • Grey: Ready/idle
  • Blue: Processing operation
  • Green: Operation completed successfully
  • Red: Error occurred
Custom Fields
TestMonitor custom fields are supported:
  • Test Cases: description, expected_value, skip_time
  • Automatic Processing: Custom fields are extracted and included in responses
  • Create/Update: Custom fields can be set during creation/updates
Security
  • Encrypted Storage: API keys are stored encrypted in Node-RED's credential system
  • HTTPS Only: All API communications use HTTPS
  • Token Based: Uses secure Bearer token authentication
  • No Logging: Sensitive data is not logged
Requirements
  • Node-RED: Version 1.0.0 or higher
  • Node.js: Version 14.0.0 or higher
  • TestMonitor Account: With API access enabled
  • Network Access: HTTPS connectivity to TestMonitor instance
Dependencies
  • axios: HTTP client for API requests
  • node-cache: Intelligent caching system
Support
For issues and feature requests:
MIT License - see LICENSE file for details.
Contributing
  1. Fork the repository
  2. Create a feature branch
  3. Make your changes
  4. Add tests if applicable
  5. Submit a pull request
Changelog
1.0.0
  • Initial release
  • Full TestMonitor API coverage
  • Comprehensive error handling
  • Intelligent caching system
  • Complete documentation
Version: 1.0.0
Updated 1 year, 6 months ago
1 in the last week
  • testmonitor-credentials
  • testmonitor-testcase
  • testmonitor
  • testing
  • test-management
  • qa
  • test-cases
  • test-runs
  • milestones
  • test-results
  • api
  • automation
  • quality-assurance
  • test-automation
  • project-management
  • madness
  • interactive
