node-red-contrib-tesla-fleet-api 1.0.2
Node-RED nodes to read your Tesla's state of charge and ~160 other read-only metrics via the official Tesla Fleet API (read-only, your own developer app, never wakes the car). Not an official Tesla tool — not affiliated with Tesla, Inc.
npm install node-red-contrib-tesla-fleet-api
Read any of your Tesla's read-only metrics (battery level, range, climate, drive state, and more) into Node-RED via the official Tesla Fleet API — with your own developer app, no paid third-party service, and it never wakes the car.
  • tesla-fleet-config — holds your credentials, manages the OAuth token lifecycle, runs a shared refresh poll (default every 15 min), and caches the latest vehicle snapshot. Settings: Refresh interval, Units (As reported / Metric / Imperial), and an onboarding Include location checkbox (adds the vehicle_location scope for latitude/longitude/heading and navigation-destination metrics).
  • tesla-fleet-single-metric (palette: Tesla single metric) — pick one metric from ~166 read-only values; choose the payload format (naked = value only, named = { key: value }, value = { "value": … }); emit on every refresh or only on change. Optional per-node Units override.
  • tesla-fleet-multiple-metrics (palette: Tesla multiple metrics) — tick any number of metrics in a grouped picker → emits one JSON object { key: value, … } on msg.payload.
All metric nodes share the config's single poll — adding more nodes does not cause extra Tesla API calls. Sending a message to a metric node's input triggers a fresh live read on demand (still never wakes the car).
Multiple vehicles. One config = one Tesla account (you do the key/onboarding once). Each metric node has a Vehicle picker; on a single-car account it auto-selects your only car, so you set nothing. The config only polls the cars that at least one node actually reads — two cars read = two vehicle_data calls per interval, a car nobody reads costs nothing.
📖 Full setup guide: https://teslametrics.github.io/node-red-contrib-tesla-fleet-api/
Why it's safe and cheap
  • Read-only. No commands, no client_secret used at runtime (the refresh grant needs only client_id + refresh_token).
  • Never wakes the car. It checks the free /vehicles state first and only calls the (billed) vehicle_data endpoint when the car is already online. Otherwise it emits the last-known value with msg.stale = true. The last snapshot is also persisted to disk so it survives a Node-RED restart.
  • Tesla gives each account ~$10/month of free Fleet API credit; a 15-minute poll stays well within it.
What you need
  1. A Tesla developer app at developer.tesla.com (grant type Authorization Code and Machine-to-Machine) → client_id + client_secret.
  2. A place to host your public key. Tesla requires partner registration with an EC public key hosted at https://<your-domain>/.well-known/appspecific/com.tesla.3p.public-key.pem. The easiest free option without running anything is fleetkey.cc: generate a key pair, upload the public key, and it gives you a domain like xxxxx.fleetkey.net. (Advanced: host it yourself on a Cloudflare Worker / GitHub Pages user-site.)
  3. A redirect page to catch the OAuth code. This repo ships one (docs/callback.html); the node's default Redirect URI is its hosted copy at https://teslametrics.github.io/node-red-contrib-tesla-fleet-api/callback.html. Register that URL in your Tesla app.
The key pair
The config node generates the EC key pair for you (the Generate key pair button) — no terminal needed. If you prefer the command line:
openssl ecparam -name prime256v1 -genkey -noout -out private-key.pem
openssl ec -in private-key.pem -pubout -out public-key.pem   # upload this to fleetkey
The private key is never used for read-only — keep it as a backup, don't host it.
…or install from the Node-RED palette manager.
Onboarding (in the editor)
  1. Drag in a Tesla single metric node and add a new Tesla Fleet config.
  2. Fill in Region, Client ID / Secret, Key Domain (your fleetkey.net domain) and Redirect URI (your callback page). Tick Include location if you want latitude/longitude/heading and navigation-destination metrics.
  3. Click 1. Generate login link → open it → log in to Tesla & approve → you land on your callback page → copy the code.
  4. Paste it into Code and click 2. Finish onboarding (this does the one-time partner registration and exchanges the code for a refresh token).
  5. Click Add/Update, then Deploy.
Already have a refresh token from the CLI (onboard.mjs)? Just paste it into the Refresh Token field and skip the buttons.
Output
Tesla single metric node (tesla-fleet-single-metric)
Selectable payload format:
Format msg.payload example
naked 48 (value only — the default)
named { "battery_level": 48 }
value { "value": 48 }
Additional message properties set on every emit:
property value
msg.metric metric key, e.g. "battery_level"
msg.unit unit string after conversion, e.g. "%"
msg.stale true when the car isn't online (value is last-known)
msg.last_updated epoch ms of the last fresh read
Default metric is battery_level, default format naked.
Tesla multiple metrics node (tesla-fleet-multiple-metrics)
property value
msg.payload one JSON object of all selected metrics, e.g. { battery_level: 48, outside_temp: 18.5, … }
Stale / offline behaviour
When the car is asleep or offline, no API call is made (the car is never woken). Both node types emit the last-known snapshot with msg.stale = true. The snapshot is persisted across Node-RED restarts.
Notes
  • Token persistence. Refresh tokens rotate on every use. Since a Node-RED node can't rewrite its own credentials at runtime, the rotated token is written to an atomic 0600 file under <userDir>/node-red-contrib-tesla-fleet-api/. It is stored in plain text (mitigated by file permissions; the token is short-lived). Re-onboarding (changing the credential) automatically supersedes the persisted token.
  • Errors. 408 = car asleep (never woken). 412 = partner registration / public key not in place. 421 = wrong region. 429 = rate limited (back off).
  • CLI alternative. onboard.mjs performs the same onboarding from a terminal and prints a refresh token — handy for testing or headless setups.
MIT
Disclaimer
This is not an official Tesla tool — it's a community-built project, not affiliated with, endorsed by, or sponsored by Tesla, Inc. It talks to Tesla's official Fleet API using your own developer credentials. Tesla and related names and logos are trademarks of Tesla, Inc., used here only to identify the API this package works with.
Version: 1.0.2
Updated 4 months, 3 weeks ago
  • tesla
  • fleet-api
  • vehicle-data
  • soc
  • state-of-charge
  • ev
  • electric-vehicle
  • battery
  • home-automation
